8 point (double square) sockets
Old Dec 28, 2004 | 10:45 PM
greyghost79's Avatar
greyghost79
Default 8 point (double square) sockets
anybody have a source for double square (8 point) sockets?
i've tried everywhere i know (and on the internet) and can't seem to find them.
thanks for any info.
Old Dec 28, 2004 | 11:00 PM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
Craftsman sells them and you can also get them from http://www.mcmaster.com/. Just search there 3/8'' Drive Sockets
Old Dec 28, 2004 | 11:02 PM
jbegler's Avatar
jbegler
What size are you needing? Have you tried your local Sears store? Craftsman makes them in 3/8"drive and 1/2" drive
I have a catalog in front of me, so if you need part numbers just let me know
Old Dec 28, 2004 | 11:21 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
SK makes them figure a set of NPT sockets 10 (Male and female) from 3/8 down will cost you $75.....
Old Dec 29, 2004 | 01:03 AM
RHD '68 L89's Avatar
RHD '68 L89
Never heard of 8 point before, what is it used on?
I know about 12 point sockets......
Old Dec 29, 2004 | 03:22 AM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
Square headed plugs. I normally use a shifter to take um off, and if that doesn't do it, an 18 inch pipe wrench. Normally have to replace them anyway.
David
Old Dec 29, 2004 | 05:12 AM
Larry B.'s Avatar
Larry B.
I got the two sizes I use for the diff plug and the trans plug. at a commercial tool supply house. They are worth tracking down. you'll never round off the corners with those.
Old Dec 29, 2004 | 05:36 AM
RHD '68 L89
I would have thought a square socket would be stronger than an 8 point but what do I know Less chance of rounding the corners as well.
Old Dec 29, 2004 | 05:51 AM
Larry B.'s Avatar
Larry B.
Sometimes you need to use a breaker bar... With a square socket you can only get 4 positions. With the 8 point you will have more choices in a confined area. Sometimes a little more room is all you need. We've all been there. It's a trade off but I have never had problems with an eight point. ANYTHING is better than pipe wrenches and vise grips. Save the vice grips for broken bolts and such.
Old Dec 29, 2004 | 08:37 AM
markdtn's Avatar
markdtn
Probably stating the obvious, but I'm sure all the tool trucks have them.
Old Dec 29, 2004 | 08:46 AM
greyghost79
yeah, that's what i want it for, the diff plug. it's 5/8 in square socket, correct?????
Old Dec 29, 2004 | 09:06 AM
bobs77vet's Avatar
bobs77vet
its like the difference between 12 pt and 6pt sometimes the angles don't workout and you need the added flexibility of the extra set of points...the SK set i have (3/8 down) is 4 points and the craftsman/powrkraft ones i have (3/8 up) are 8 point....
and to make matters worse when i had one plug (female) that was enlarged i had to take a 3/8 hex head socket and grind it down....no way was i going to grind down my expensive ones....
Old Dec 29, 2004 | 11:31 AM
mvftw's Avatar
mvftw
I bought mine at Sears last year, but there were being discontinued...
To 8 point (double square) sockets
