Few beginner questions
Old Dec 29, 2004 | 01:59 AM
rotaryxperimentseven's Avatar
Cruising
Default Few beginner questions
First off I know I could spend probably 1 1/2 searching and answer these questions but a few quick yes and no answers would be much appreciated.
1. Is '82 the only year that C3's were fuel injected?
2. Did all small block Vette's come with a 5.7?
3. Also how cramped is the engine bay, would there be room for say a pair a turbos?
thanks in advance.
Jeff
Old Dec 29, 2004 | 02:04 AM
Contrail's Avatar
Contrail
1. Yes
2. No, in 1980 California Emissions Corvettes had a 305
3. There is room for a pair of Turbos, but it requires modification.
Old Dec 29, 2004 | 02:24 AM
Kalway's Avatar
Kalway
Be wary of '82's, unless properly cared for. Crossfire injection is quite a beast. There's a reason it was only used for 2 production years.
Old Dec 29, 2004 | 02:52 AM
Cruising
hmm alright
Well here is what I'm wanting to do. I want to build a twin turbo V8 car and I have decided to either start with a 3rd gen f-body or a C3 vette. I'll be doing all the installation and fabrication myself and just really don't want to have to screw around with a blow-through system and tuning a carb for the turbos. What would you suggest.
If I had my choice I would definatly go with the vette, but if the crossfire injection won't work very well then I guess it's a no go. Is there and way to maybe put a TBI system on a C3 vette? Also any idea what I could expect to pay for a decent running '82, cost will be a factor, and I know it would be alot cheaper to go with a f-body, but the vette looks ten times better.
I drive a '94 Rx-7 now which is lots of fun, I just need something with some torque to drive sometimes, and something for me and my dad to do this summer.
thanks again
Jeff
Old Dec 29, 2004 | 03:04 AM
Schmucker's Avatar
Schmucker
If you're going with twin turbos you should really just go with aftermarket fuel injection. It is really the only logical path with forced induction. I don't think the dual throttle bodies on the Crossfire can squirt enough fuel to feed that much air.
Old Dec 29, 2004 | 03:12 AM
munday's Avatar
munday
maybe a tpi upgrade and some bigger injectors and a fbody turbo kit.
Old Dec 29, 2004 | 03:33 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
There are a couple twin turbo vettes and people making them.
I am working on such a project myself.
What are your power goals? And what will the car be used for? and what kind of budget are we talking?
Here is an idea I wish I had tossed around.
put this http://www.superchargersonline.com/p...er=SAT-4150R-S
on top of a holley or whatever TBI injection system. THe holley commander computer can support up to 4 low impedence injectors. which should be good for a pretty healthy engine. But your not gonna have a 1000hp small block.
If you want to run a port fuel injection I would probably go with the accel sequential fire injection. You can make some crazy power with them.
If you have reasonable power goals(600-700hp), like me you could run some old grand national turbos and pick them up fairly cheap.
Just some ideas.
Old Dec 29, 2004 | 07:57 AM
PatsLs1vette's Avatar
PatsLs1vette
You can get any year and inject it then twin turbo it,dont stick with one year espeically if your building a new motor for it anway.
Old Dec 29, 2004 | 08:52 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
I'de also look into any year but 80-82 for stronger suspension parts. You can always put the 80-82 bumpers on a different year. Try a 78-79 or any other rubber bumper year.
Old Dec 29, 2004 | 04:37 PM
blackshark82's Avatar
blackshark82
Try looking up Twin_Turbo on the forum. Marck Jongman in the Netherlands has an 82 crossfire modified with twin turbos and knows a lot.
Old Dec 29, 2004 | 06:46 PM
Cruising
[QUOTE=Guru_4_hire]
QUOTE]
That is actually exactly what I had in mind with the turbo's, what turbo's are they exactly, t-26's?
As far as power around 600ish would be great, and I would definatley not be daily driving the car. Probably mostly just track use, drive on the weekends kinda thing.
Thanks for the info I guess I just didn't realize there were fuel injection kits out there. Hopefully I'll get everything planned out and start scavenging parts soon.
Jeff
To Few beginner questions
