Question about PCV?
Old Dec 29, 2004 | 10:09 PM
wsnider74's Avatar
wsnider74
Cruising
Default Question about PCV?
I have a '74 with a 350 that has after market valve covers and air intake. The PCV was routed to the vacuum tower at the rear of the manifold. My question is do I need the PCV at all, or is a filler/vent cap on each valve cover enough. Or should I drill a hole in the base of the air filter housing and run a line from the PVC to there?
Old Dec 29, 2004 | 10:14 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Do a forum search, there have been many posts about this. Bottom line, you want the PCV. A breather on the other valve cover is ok, you don't necessarily have to pipe to the air cleaner on that side.
Old Dec 29, 2004 | 10:35 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i agree you want a pcv hose ....why do you think you don't want it?
Old Dec 29, 2004 | 10:48 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
The air cleaner housing, while a good source of fresh air into the crankcase on a PCV system, is not a vacuum source as the PCV valve needs. The only source of vacuum is the intake manifold, preferably through the carb base as it was designed for. Routing it directly to the manifold works but the crankcase fumes to be reburnt will be distributed more equally to all cylinders, rather than just the rear ones, if hooked to the carb.
Old Dec 29, 2004 | 10:54 PM
Glassbowtie77's Avatar
Glassbowtie77
Old Dec 30, 2004 | 04:28 AM
randy814u's Avatar
randy814u
Lol, this forum is great. I am just putting in a engine with a bunch of changes, and had not got to the final hooking up, the pcv etc. And here you guys answer me even before I could wonder about it. Thanks, Randy
Old Dec 30, 2004 | 09:24 AM
AGVI's Avatar
AGVI
Canadian Events Coordinator
What happens if you run with out one?
Old Dec 30, 2004 | 09:48 AM
wsnider74's Avatar
wsnider74
Cruising
Thanks for the advise, I will be hooking the PCV up today or tomorow. However does anyone know what type of Holley I have?(unable to post pictures). There are only 3 vacuum ports on the carb; 1. large opening at base on the pax. side at rear, I plan to run the brakes here. 2. on the front fuel bowl, now runs the dist. advance. 3. Small port below the front bowl.
My plan is to run the head lights, and transmission to the vacuum tree on the manifold. The dist. advance will stay on the front fuel bowl. And the power brakes to the large port on the rt. rear base of carb. If it would be enough vacuum I will run the PCV to the small port below the front fuel bowl.
And finally can someone recommend a good book on Holley carbs that might show some of the vacuum line setups.
Old Dec 30, 2004 | 09:59 AM
Paul L's Avatar
Paul L
That port on the rear passenger side is for the PCV. I would not use that for the brakes. Install a T-fitting on the rear manifold and get brake vacuum from there. My pic shows brakes and transmission vacuum modulator at that source. With a four-speed the latter is obviously not needed.
Here is that carb barebones. It is a model 4160/3810.
Old Dec 30, 2004 | 10:22 AM
mrherren's Avatar
mrherren
I've never ran the PVC, and now you have me wondering. So 2 questions. 1. Why PVC, what is the benifit? 2. Paul67 why don't you want to connect the brakes to the carb?
Thanks,
Marc
Old Dec 30, 2004 | 10:32 AM
Paul L's Avatar
Paul L
You want the blowby/crankcase gases coming through the PCV to be reburnt. Hence the connection to the carb. Connecting the brake vacuum there will defeat the purpose of the PCV.
As to its purpose there is an informative article here.
http://www.autosite.com/garage/encyclop/ency08b.asp
To Question about PCV?
