Question for TH200R4 users - driveshaft length..
Dec 30, 2004 | 07:45 AM
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I wonder what length driveshaft I'll have to use with the 200R4?? Is it the same length as a TH350 driveshaft? If yes, what year C3's came with a TH350?
Dec 30, 2004 | 07:54 AM
Dec 30, 2004 | 08:02 AM
Thanks!
Dec 30, 2004 | 01:48 PM
I used the same driveshaft when I replaced my TH400. The only thing I had to change wa the front universal. I had to change it to a off-set style because the yoke is smaller then the driveshaft. It was a standard shelf item at every parts store.
Dec 30, 2004 | 01:53 PM
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
for what its worth my 77 th350 driveshaft i just shortend was 31" and i cut off 3" to make it 28" for my 700r4 install
Dec 30, 2004 | 07:07 PM
Quote:
The 700R4 is a few inches longer than the TH200R4
Dec 30, 2004 | 07:20 PM
Quote:
they say it is 3.125" longer but for some reason i thought the 200r4 and th350 are the same length?
Dec 30, 2004 | 07:29 PM
I think that's correct!!
Dec 30, 2004 | 07:38 PM
so for a double check a 31" drive shaft is what you are looking for....measured from the u joint cap to ujoint cap....the search begins...
Dec 30, 2004 | 08:10 PM
I'll try to get a used driveshaft from a C3 with TH350 until I'll get a custom built driveshaft when I'll have my Ford 9 inch installed..
Dec 30, 2004 | 09:25 PM
Olivier,
My stock driveshaft worked. I had a TH350 in my 79.
Dec 30, 2004 | 09:47 PM
Quote:
Originally Posted by isosceles
Olivier,
Now I have to find a used driveshaft + yoke for my temporary setup until I'll get the Ford 9 inch installed...
