How'd you do it?
Old Dec 30, 2004 | 05:48 PM
73 Vet's Avatar
73 Vet
Default How'd you do it?
I just rebuilt/replaced my trailing arms. Removal was easy on one side, hell on the other. BUT, getting the new bolts in was quite a challenge. I used pliers, vise-grips, magnets, fingers, and bad, bad words. What did you all do?
Old Dec 30, 2004 | 06:20 PM
Missileman's Avatar
Missileman
I use thin, single strand wire. Feed throug the TA hole from the outboard side, then twist around the threaded portion of the bolt or attach through the cotter pin hole in the bolt if the wire is thin enough, then pull through. If you use the cotter pin hole method, you can also feed the nut down the wire and start the nut using the wire to keep it from spinning.
Old Dec 30, 2004 | 08:59 PM
1979toy's Avatar
1979toy
I used a piece of rubber tubing over the end of the bolt. Fed the tubing in from the outside and attached it to the bolt in the frame channel and SLOWLY pulled the bolt through.
Old Dec 30, 2004 | 09:02 PM
Jack71's Avatar
Jack71
Oh my god. I hope I never have to do that job.
Old Dec 30, 2004 | 09:08 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I used needle nose pliers and noticed that they slip off the bolt when trying to insert them from the inside.... after consulting Miller Lite (five minute beer-break and a lot of bad words..) I just glued the pliers to the bolt (Liquid Nails) and .... it works like a dream
Old Dec 31, 2004 | 12:45 AM
NHvette's Avatar
NHvette
Do it the easy way ... take a three year body-off break.
Without all that pesky fiberglass in the way, it's a piece of cake.
Seriously, I have heard the wire or fishingline works well to pull the bolt through.
Old Dec 31, 2004 | 03:23 AM
startwith80vette's Avatar
startwith80vette
I cursed alot, eventually it went through, I found cursing a lot helps
Old Dec 31, 2004 | 05:39 AM
jdmick's Avatar
jdmick
I took someones advice from here and bought a couple of VERY long needle nose pliers from Harbor Freight. I hung the TA fairly level with a wire to get the hole in the right place and stuck em in. Unlike most of the project this part went a lot EASIER than I thought it would.
Old Dec 31, 2004 | 09:10 AM
rrent's Avatar
rrent
Having already read the saws-all and other horror stories here on the forum -- I wienied (wienered...wimped...?) out and I wrote a check at the local Corvette Specialties ---
Old Dec 31, 2004 | 10:21 AM
EDDIEJ82's Avatar
EDDIEJ82
To How'd you do it?
