HELP!! Flywheel Issues!
Old Dec 30, 2004 | 09:05 PM
jacobsed's Avatar
jacobsed
Default HELP!! Flywheel Issues!
I am converting my 79 L48 from an automatic to a manual.
I bought a borg warner tranny, flywheel, belhousing, ect.. that came from a 78 L82. Went to install the flywheel and the center hole is
about 1/4" smaller in diameter than the flange on the crank. My 79's
engine came from a 72 Camaro. Is there an adapter plate? Or do I need to buy a new flywheel? Or will a shop widen the hole for me? What is the best solution here? Is there a crank for an automatic and a different crank for a manual?
Old Dec 30, 2004 | 10:59 PM
jacobsed's Avatar
jacobsed
bump
Old Dec 30, 2004 | 11:20 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
crankshafts are the same for auto/man.... i don't see why a machineshop couldn't widen the hole for you.....i'd would probalby try and find out why it isn't lining up and make sure there aren't any other differences such as offsets,bolt holes...etc... i would try and figure out what crank i had in there as a first priority....
Old Dec 30, 2004 | 11:23 PM
L88Plus's Avatar
L88Plus
Only ones I know of with smaller diameter center hole are the ones made for late model stuff. Different bolt pattern as well and aren't interchangable. You might want to check this out. I don't think they balance the same, either, so double check before you bolt it on. HTH
Old Dec 30, 2004 | 11:30 PM
bobs77vet's Avatar
bobs77vet
just out of curiosity how do you know you have a 350 instead of a 327 or something else?
Old Dec 30, 2004 | 11:41 PM
jacobsed's Avatar
jacobsed
I'm 99.99% certain it was built as a 350. What would be a definitive way to tell? What should the diameter of the hole in the flywheel be? Again, this crank works fine with the automatic tranny setup.
Old Dec 31, 2004 | 12:05 AM
ltlevil's Avatar
ltlevil
It doesn't matter if it was a 350, 327, 302(oh-yeah that was in '69 or '68 1/2 ), or any thing else if the motor is a small block Chev. the crank hub is not different between 72 and 79 whether it is a small/big block.
Old Dec 31, 2004 | 12:08 AM
bobs77vet's Avatar
bobs77vet
well so much for that idea...
Old Dec 31, 2004 | 12:41 AM
ltlevil's Avatar
ltlevil
Something else, I'm not sure if you explained this correctly or not or if I understood this correctly or not, but are you talking about the flywheel "hole" or where the trans input shaft goes into the crank?
Old Dec 31, 2004 | 06:38 AM
jacobsed's Avatar
jacobsed
The flywheel hole.
Old Dec 31, 2004 | 06:55 AM
toyvet1's Avatar
toyvet1
When you look at the back of the block does it have a one or two piece rear seal. You might have a newer style block that use a differant type crank. One piece rear seals you can see the seal when looking at the back of the block. Just a idea....
Old Dec 31, 2004 | 08:36 AM
theandies's Avatar
theandies
Thats what I was thinking. You can also measure the space between the flywheel mounting bolts. The new style block with the one-piece rear main seal has a crank bolt pattern that is smaller, 3.0” compared to 3.58” on the old style cranks.
Old Dec 31, 2004 | 08:54 AM
SteveG75's Avatar
SteveG75
When GM made the motors, they sometimes ID'ed the ones for automatics earlier. This allowed them to to skip some of the machining on the rear of the crank (saved $$$).
Make sure that you have a machined hole for the pilot bearing as well.
Old Dec 31, 2004 | 10:35 AM
stingr69's Avatar
stingr69
It is a Ford engine and a Chrysler flywheel. Get a bigger hammer and make it fit
Seriously, you can ID the engine by looking at the back of the crank flange. The 283 has a full round flange, the 302 has the single notch on a round flange, the 327 small journal has a round flange with 2 notches, the 327 large journal has a round flange with 2 notches and a fan shaped counterweight, the 350 looks the same as the large journal 327 but the counterweight is full width across the top of the flange. Manual or automatic are the same piece but the manual needs to have a pilot bushing installed in the back of the crank.
I would get a new flywheel. They do not cost that much and besides, who knows what you realy got from the other guy.
-Mark.
Old Dec 31, 2004 | 11:15 AM
jacobsed's Avatar
jacobsed
OK, thanks for the input.
I just got a used flywheel out of the salvage yard and had it machined down. $20 for the flywheel and $20 for the machining. I have a 350 with a 2 piece rear main seal. The flywheel that I initially had was for a newer engine because it had a smaller center hole and the bolt holes were offset. I'm off to the garage to finish mounting this bad boy up.
Old Dec 31, 2004 | 11:19 AM
comp's Avatar
comp
think i did run into this a Long time ago
To HELP!! Flywheel Issues!
