80 conversion to 700r4?
Old Dec 31, 2004 | 04:35 PM
Joebio's Avatar
Joebio
Default 80 conversion to 700r4?
Well I got the tranny for the bubble so I can justify spending some money to put it in. besides the crossmember what else do I need?
Old Dec 31, 2004 | 04:42 PM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
www.bowtieoverdrives.com I know you will need to shorten the driveshaft. That is why a 200 4r is better, basicly a bolt in, no need to shorten driveshaft, and it doesn't have such an aggressive 1st gear.
David
Old Dec 31, 2004 | 04:44 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
I put a 700/R4 in my 81, the driveshaft needs to be cut
down to 25.5 to be correct.
Old Dec 31, 2004 | 05:59 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
shorten drive shaft, new crossmember, if your car has a carburetor you need to get a TV cable bracket, you need to install a new solenoid kit in the transmission, you need a new detent in the consol, and you need to hookup a lockout relay kit....
i just did this in a 77, i used all the kits from Bow Tie Overdrive
see page 1 and page 3
http://forums.corvetteforum.com/showthread.php?t=960162
Old Dec 31, 2004 | 06:28 PM
ffvetteman's Avatar
ffvetteman
bob, not counting the tranny, how much did it cost. Looking at doin this?
Also what do you need to do to the crossmember?
Old Dec 31, 2004 | 09:13 PM
carl a's Avatar
carl a
when i did the changeover to the 700r-4,,in my 73,, all i did was call boetie, thet walked my cousin(who built the trans) and myself thru the whole procedure and sold us all the necesssary parts to do the conversion
Old Dec 31, 2004 | 11:25 PM
ffvetteman's Avatar
ffvetteman
Cool thanks
Something I want to takle sometime
Old Jan 1, 2005 | 08:58 AM
bobs77vet's Avatar
bobs77vet
its all from bowtie over drives
don't have receipts in front of me but this is what i remember
crossmember 179, realay kit 45, TV cable & brackets 100, consol shift kit $110, pressure gauge 30, throttle bracket 10...what am i missing i thought it was 574 total?
used trans and TC from a friend 300, drive shaft shortened and rebalanced 85, trans filter and gasket kit 20
you asked about the crossmember....you buy an engineered one from bow tie over drive....it is 6 bolts to remove and easy to take out and put in....this is not a problem in any way....the least of your concerns
To 80 conversion to 700r4?
