torque wrench
Old Dec 31, 2004 | 06:53 PM
greyghost79's Avatar
greyghost79
Default torque wrench
who makes a good quality torque wrench, preferably one that you can "set" which "releases" when you reach the specified torque?
also, is there a way to calibrate the torque wrench so that you'll know what it's reading is correct?
Old Dec 31, 2004 | 06:57 PM
Master Ho's Avatar
Master Ho
There are a number of torque wrench calibration tools on the market. If you want to spend some $$$, try SnapOn. Otherwise, check with the tool distributors to see who has one you could use/borrow...
Old Dec 31, 2004 | 07:50 PM
RMS73's Avatar
RMS73
My torque wrenches are either Snap-On or Sears.
When new the torque wrenches came with a calibration record. Only if you use it quite a bit does it need recalibration every year. I know the Snap-On rep does it for free at my work place.
Roger
Old Dec 31, 2004 | 08:13 PM
72LS1Vette's Avatar
72LS1Vette
I just received a new Craftsman torque wrench for Christmas. It has a dial indicator for lb-ft or N-m (whatever those are) and will release when the proper torque is reached. I don't know how accurate it is yet but I can compare it to the old crapola dial wrench to get an idea.
I was just bitching to my son as I was putting his transmission back in his car that the next tool I was going to buy was a ratcheting torque wrench and I found one under the tree the next day!
Rick B.
Old Dec 31, 2004 | 09:04 PM
etteroc27's Avatar
etteroc27
Snap on.
Old Dec 31, 2004 | 09:09 PM
carl a's Avatar
carl a
about how much does a good quality one cost?
Old Dec 31, 2004 | 09:12 PM
77 vette's Avatar
77 vette
I get all my measuring tools (dial indicator, calipers, torque wrenches ect) calibrated a work for free, it's required to have updated certified tools when working on 747 wide body aircraft.
Old Dec 31, 2004 | 09:25 PM
68/70Vette's Avatar
68/70Vette
Roger
My opinion also. My Snap-on wrenches will be calibrated without charge. The Sears wrenches will not. My Sears wrenches are , as far as I can tell, SK torque wrenches. If I had it do do over again, I would buy all my torque wrenches from Snap-On and just grin and bear it for the added extra expense.
Old Dec 31, 2004 | 11:53 PM
73jst4fun's Avatar
73jst4fun
Just got a Snap on torque wrench, I also found alot of torque wrenches on Ebay, check them out and save some $$$$
Old Jan 1, 2005 | 12:01 AM
greyghost79
the Snap On rep in my area never returns my phone calls. guess he just likes to make the big sales and the dealerships. can i order their stuff direct??
Old Jan 1, 2005 | 12:09 AM
Carl Granquist's Avatar
Carl Granquist
There's gotta be someone out there who can put a dollar figure on a "Snap On" brand torque wrench, right? How much more than the $60 Sears model? Just curious. And is it worth the extra? I'm in the market for a good one and only want to purchase once. Thanks.
Old Jan 1, 2005 | 12:49 AM
lostpatrolman's Avatar
lostpatrolman
I remember a while ago some guys were saying proto made a very good torque wrench with comparable prices.
Old Jan 1, 2005 | 02:16 AM
Stoge's Avatar
Stoge
Those are newton-meters and usually for our non SAE friends.
Old Jan 1, 2005 | 08:28 AM
bob_robert's Avatar
bob_robert
It all depends on how much $$ you want to spend. The top players are Snap-On, Proto or Mac (both the same), Matco, CDI. Craftsman is in the middle of the road. If you want to see who manufactures what go to http://ww3.hti.org/ and search "List of Mfgers". Many have web sites that you can view their catalogs.
What ever Micro-Adjustable TW you buy always be sure to reset the TW to it's lowest setting when finished and NEVER, EVER use the TW to break loose any fasteners. Proper care will keep your wrench in calibration for a long time.
Old Jan 1, 2005 | 08:59 AM
markdtn's Avatar
markdtn
I bought my Snap-On off Ebay a few years ago. It's a clicker 1/2", like 30-120 ft-lb, and I paid about $85 shipped I think. It had a recent calibration record when I got it. Before that I had a beam-type Sears. It was OK,-but I lake the Snap-On better.
Old Jan 1, 2005 | 10:43 AM
mark79,80's Avatar
mark79,80
This has been mentioned in previous threads, but as a reminder the
Craftsman torque wrenches do not have a lifetime warranty like other
Craftsman tools. Had their top of the line digital wrench fail so it
caused me to strip several lug nuts and break off a wheel stud while
checking the torque. Took it back and they wanted $175 to send it
for repair, cost new $99. Took it home and took it apart and found
that the digital numbers that are mounted to a shaft had slipped
causing the calibration to be way off. Wrench now makes a good
breaker bar.
Bought a new SK wrench and other tools from the below link. Found
their prices to be excellent, always quick delivery and everything in
stock:
http://www.thetoolwarehouse.net/shop...erService.html
Old Jan 1, 2005 | 11:29 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I've had the same issue. Not much point in the extra expense if you can't get the service. I've seen used wrenches on EBay for slightly more than double the price of a new Sear's tool.
I've never had issues with getting Sear's tools replaced when broken but I've never had a torque wrench break so the other posts could be right. Although any tool can break, I'd think that for the amount of use that you'll need, a middle of the road tool should do the job well.
Having said that, I'm also pretty concerned about the conversion from Craftsman to Kraftsman,
Old Jan 1, 2005 | 01:02 PM
reckerrp98's Avatar
reckerrp98
Just got one from Sears...it's great. $59.99 and dials up 20-200 ft/lbs. Lifetime warranty. I worked aircraft maintenance for a while and the single best thing you can do to prolong the calibration of your wrench is to dial it down after each use. Don't leave it dialed up and sitting in your toolbox, or it will go out of cal quickly.
To torque wrench
