OK, help needed here.
Its getting near time to do my engine rebuild and while its all apart may bite the " Bullit" and get the stroker side of life sorted out.
Seems from general reading that most people go for a 383 which I am told that with a 40 rebore will end up at 390 or was it 400.
If I got it right the next step up is 406 or thereabouts ??
So whats the pros and cons of the various combinations.
Are there any particularly good or bad 383's by manufacturer or design ??
New parts in the cupboard waiting are 58cc alloy heads, torker manifold, roller rockers, faster cam, etc.
Got nothing for the bottom end so far - but the cheque book is burning a hole in my pocket...............
350 Block 30 over 400 stroke - 383
350 Block 40 over 400 stroke - 385
The 406 is not a step up, it is different, based on the siamesed bore 400 block.
I have no idea who told you that boring 40 over will get you 390 of 400 ci, but I would not believe too much from that person. Computing cubic inches for an engine is about as basic as it get. If they can't do that, they shouldn't be offering any advice.
As Ganey pointed out, the 400 is a siamesed cylinder block. This can cause cooling issues, although there are plenty of folks out there with big-inch strokers based on this block with no problems. Also, the 400 is a two-bolt block from the factory. I opted for an early 4-bolt 350 block stroked to 383 cubes. Fully forged Eagle 4340 bottom end with H-beam rods and pistons with file-fit rings. 454HP/480TQ at the crank.
It really depends on what you want to do. The less expensive stuff is probably OK for the street.
Jeff
They came as both 2 and 4 bolt mains. I used to have one back in the 80s. My dad got rid of it when I moved out. He gave away a 350 4 bolt a 400 4 bolt and a 454 4 bolt. Doh! I had no place to store them and he wanted them out!
Hold on.............lets not get this all wrong from the start.
Maybe its me mis-reading but I thought..............
1. A stroker kit is basically a new crank, rods and pistong which without a rebore will give 383 cubes.
2. If you rebore at the same time - depending on that rebore, +10, 20, 40 or whatever, then you will get 383 plus the rebore, so 400 cubes for example.
No you got the right idea but for each overbore size (+10, 20, 30etc) the change in displacement is not that much....383.....385.....388....and so on. to reach 400 ci with a 350 block you would have no cylinder wall left.
on this engine they are using a 4.00" stroke----so this is a 406 stroker bsaed on a 350 block............383 use a 3.75" stroke.........350 use a 3.48" stroke.....so the extra cubes come from stroke not bore.
2*3.14*radius of cylinder*stroke in cylinder* 8cylinders=volume (ci)
A 4 inch stroke in a 350 is really pushing the limits. The 3.75 is no problem. You might have to use a small base circle cam in the 4 inch stroke. A lot of grinding is needed with a 4 inch stroke.
cheers:
If you look at what oregonsharkman said, he simply stated the stroke,
which I did not put in.
I almost put it in originally like this:
350 Block 30 over 400 stroke (3.75) - 383
So that's still correct.
Duntov determined that 3.75 was the longest stroke the SB was happy w/ for racing.
The early 400 blocks were 4 bolt because they were originally intended to be high perf. engines.
