Speed Bleeder Screws
Old Jan 2, 2005 | 01:05 PM
CORKYVET's Avatar
CORKYVET
Default Speed Bleeder Screws
Anyone using these? If so, are you pleased? I normally do the bleeding alone, so looks like a more efficient way than the cup and tube with lots of brake fluid. Thanks in advance.
Old Jan 2, 2005 | 01:27 PM
LiveandLetDrive's Avatar
LiveandLetDrive
Yup, I use them, they're very easy to use. Unless you have a second person, you can't see whether there are bubbles in the fluid though. My solution is the "brute force" method of using tons of fluid until there is little doubt.
-Chris
Old Jan 2, 2005 | 01:29 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
either brute force or a long piece of clear tub.. eiher way you use a lot of fluid....
Old Jan 2, 2005 | 01:51 PM
greyghost79's Avatar
greyghost79
use a power bleeder. best way. i bought some "speed bleeders" but they didn't seem to fit my calipers. to big. maybe they make different sizes?????
Old Jan 2, 2005 | 06:11 PM
RMS73's Avatar
RMS73
I have the speed bleeders, but if you have alot of air in the brake system it will take awhile to bleed it. It took me the last three days to get my brakes working again. I replaced the calipers pistons. Finially I made a cheapie speeder bleeder, lexan plate and my bicycle tire pump, and the system was bled in about 20 minutes.
Roger
Old Jan 2, 2005 | 07:35 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
hold on......don't those cost like $8 a piece 8x6 = $48....what does a motive pressure bleeder cost $55.....i'd go with the pressure bleeder
To Speed Bleeder Screws
