Frost King Installed?
Old Jan 6, 2005 | 04:18 PM
Mike Mercury's Avatar
Mike Mercury
there are "blankets" made specifically to handle the heat genetated by engines and transmissions.
Old Jan 6, 2005 | 04:19 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Originally Posted by Mike Mercury
It's kinda risky to use the FK and Reflectix outside of the cockpit. Both have high temp ratings to 180 degrees. Above that the dense foam of the FK will turn into putty; and the plastic bubble insulator used on the Reflectix will start to melt.
If Reflectix is the stuff with the bubbles in it, it did melt from my catayltic converter....
Old Jan 6, 2005 | 04:22 PM
Mike Mercury
it is... and the Frost King wouldn't of held up either.
Old Jan 6, 2005 | 04:52 PM
norvalwilhelm's Avatar
norvalwilhelm
The product we get is not frost king but I assumed it was the same. It is Duct insulation from HOME Hardware. It is foam backed with aluminum coating , self adhesive and will not burn even we put very very close to hot headers, A friend did a test and with a propane torch on it it wouldn't burn.
I don't have a part number but will tomorrow when I pick up my order.
Old Jan 6, 2005 | 07:01 PM
73 Vet's Avatar
73 Vet
Well, I'm totally confused now. Sorry, but, what product CAN be used UNDER the TUNNEL, and what product(s) are used inside, and, OVER the TUNNEL?????
Old Jan 6, 2005 | 07:31 PM
Mike Mercury
cool. The more choices... the better. Can you get the MFGR;s name and their part number; along with the stores part number?
Old Jan 6, 2005 | 07:55 PM
bobs77vet's Avatar
bobs77vet
Zeroclearance is expensive, but it is specifically designed for exterior automotive purposes including under vehicle, engine compartments etc....
Old Jan 6, 2005 | 08:30 PM
trevkris2's Avatar
trevkris2
OK...maybe I've missed it along the way, so I appologize in advance...
How does the Frost King stuff stick to the panels? Do you use spray adhesive like the 3M stuff? Whta would a guy have invested for an entire interior? Thanks.
Old Jan 6, 2005 | 08:51 PM
Mike Mercury
already comes adhesive backed:
http://mikemercury.home.att.net/sound.htm
Old Jan 6, 2005 | 09:15 PM
trevkris2's Avatar
trevkris2
Awesome stuff! I'm headed to Home Depot tonight baby!!
