removable rear window
Old Jan 6, 2005 | 11:54 AM
chevymetal's Avatar
chevymetal
ffvetteman.....do it for me buddy.....i will follow in my 77....pls make notes, part number prices, vendors etc... etc thks bob
hi again. i found this site while searching google last night for some info.
http://www.1-4u-computer-graphics.co...num=1059534495
you have to sign up to read threads i think, but it just signs you up automatically, no checking email, then going to a link to verify etc. only takes about 20 seconds
anyway, its got a good write up on doing this for a 77.
the reason i am looking for this information, is because i am curious if somehow i can adapt it to a pontiac fiero GT rear window.
although the window is a bit larger than the corvette window, i dont think it would be that hard to do. another hurdle is the third brakelight at the top of the window. it is inside the car, and almost right up against the window. this kind of prevents it from falling inward to remove it. maybe have to look into relocating the light a bit forward to let the window clear it. or maybe somehow integrating it into the latching mechanisim???
you can see the brake light here.
also thinking of an SBC swap, maybe an LT1 or LS1, but thats another thread/forum
Old Jan 6, 2005 | 12:42 PM
Lotus76's Avatar
Lotus76
Default Yes you can get a kit!
Originally Posted by carl a
do they sell these kits for a 73???
Yes, you can buy the rear window conversion in a turn key kit from Alex Nelsen at Vette Specialties http://www.vettespecialties.com
C-3 Window Conversion $500.00
Enjoy your 1973-77 Corvette the way the designers at GM meant. Convert your fixed rear window to the earlier removable window. Comes with new weatherstrip, latches, hardware, and black rear window trim.(Order Dye below to color match your interior.) The window is a hand selected good used unit.
Rear window conversion with new window $725.00
Same as above except with a new window and frame.
While Alex was creating this package I got mine from Steve at Dynamic Corvettes. www.dyanmiccorvettes.com from a doner car.
Its one of the best things I have done for just a plain feeling good when driving the vette . I did not have the t tops or the window in all summer. feels a lot like a vert. and gets lots of questions too.
Old Jan 6, 2005 | 12:51 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
lotus76...thks
Old Jan 6, 2005 | 02:07 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Originally Posted by SharkPilot
It baffles me that Chevy discontinued the removable window in 1973.:
I recall reading somewhere that none other than Zora Arkus Duntov want the removable window eliminated. He claimed that with the window removed, the T-Tops off and the side windows rolled up there was too much wind turbulance in the cockpit at speeds above 100 mph.
As for leak problems, my T-Tops with brand new weather stripping leak, my rear window with 35 year old weather stripping have never leaked. Go figure.
Old Jan 6, 2005 | 02:53 PM
Detroit Vette's Avatar
Detroit Vette
I have a rear window assembly from a 1969. It will work in your car. The hardware is driver quality original parts. You can buff most scratches from the glass. I'd take 300.00 for the complete assembly. I think you will have to swap out your upper trim pieces with the 68-72 style to clear the window latches. You may also need to change your window seal. If you buy the kit i will give you the seal and new trim panels for my cost. Corvetteworks@aol.com
Old Jan 6, 2005 | 03:04 PM
WillRace4Food's Avatar
WillRace4Food
would these converstions work with a rear window defoger? One of the few options on my vette and I would like to keep it
Old Jan 6, 2005 | 03:09 PM
ffvetteman's Avatar
ffvetteman
Im looking into it and Ill keep you informed
Old Jan 6, 2005 | 03:19 PM
Detroit Vette
this will have no impact on your rear defogger system.
Old Jan 6, 2005 | 03:33 PM
NHvette's Avatar
NHvette
- as long as it's the original blower/duct defogger.
If an aftermarket (stickon) resistance wire type - then probably not.
But: No window ... no fog ... no cleaning.
