Bad lifter?
Old Jan 5, 2005 | 07:15 PM
Scudd's Avatar
Scudd
Default Bad lifter?
How would I know if I have a bad lifter, and are they easy to fix? I hear a tapping sound from the motor when its cold. The sound seems to go away after the car warms up a bit. It sounds like its coming from the top of the motor, around the area of the valve cover. Thanks
Old Jan 5, 2005 | 07:17 PM
fast idle's Avatar
fast idle
although possible it's not likely, you probably just need the valves adjusted.
Old Jan 5, 2005 | 08:05 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Check the valve adjustment first - this is easy to do and all you need to replace is two inexpensive valve cover gaskets...
If this does not help then it may be a lifter..... these are not expensive either but you'll have to take the valve covers and the intake off.....
You're saying the noise is gone when the engine is warm... it could be a lifter that is just beginning to fail.... you don't have to fix it immediately, it will get louder over time...then it's time to fix it....
Old Jan 5, 2005 | 09:36 PM
75 Stingray!'s Avatar
75 Stingray!
Check for exhaust leaks around the heads first.
Old Jan 5, 2005 | 11:27 PM
isosceles's Avatar
isosceles
check my earlier post. I got fooled into thinking it was valves too.
http://forums.corvetteforum.com/showthread.php?t=985193
if it IS a bad lifter (assuming hydraulic) Marvel Mystery oil works wonders!
To Bad lifter?
