ZZ3 vs. ZZ4
Old Jan 6, 2005 | 03:07 PM
Roadster71's Avatar
Roadster71
Default ZZ3 vs. ZZ4
What are the differences?
Old Jan 6, 2005 | 03:49 PM
PatsLs1vette's Avatar
PatsLs1vette
the zz3 was 345 hp and the zz4 was 355 hp,
specs on zz3
High Output 350 (ZZ3)
PN: 10185072
Cost: about $3000 (includes many accessories, intake, distributer and water pump)
Displacement: 350 cubic inches (5.7L)
Horsepower: 345 at 5200 rpm
Torque: 387 lb-ft at 3250 rpm
Max RPM: 5800
Compression ratio: 9.8:1
Bore & Stroke: 4.00" x 3.48"
Pistons: Cast hypereutectic aluminum
Rods: 1053 forged steel "pink"
Heads: Cast aluminum, angled plugs, 58cc
Head specs: 1.94"/1.50"
Camshaft: Hydraulic roller tappet
Cam specs: 208/221 .474"/.510" 308/316 (advertised)
Idle: 750 rpm
Part Number: 24502609 (ZZ4)
Displacement: 5.7-liter (350 c.i.d.)
Bore/Stroke: 4.00”x3.48”
Engine Block: 10105123 Four Bolt Main, Cast Iron
Compression Ratio: 10:1
Pistons: High silicon aluminum piston with offset pins, 10159436.
Crankshaft: 12556307 Forged Steel
Connecting Rods: 10108688 PM rods
Camshaft: Hydraulic roller tappet (#10185071)
Valve Lift (Intake/Exhaust): .474”/.510”
Duration (Intake/Exhaust): 208°/221° @ .050” tappet lift
Valve Lash (Intake/Exhaust): Zero/Zero
Cylinder Heads: Aluminum, 58cc chambers, 12556463.
Valve Diameter (Intake/Exhaust): 1.94”/1.50”
Valve Springs: LT4 chrome silicon, 12551483.
Rocker Arm Ratio: 1.5:1, 10089648
Distributor: HEI with centrifugal and vacuum advance, 01104067.
Spark Plugs: MR43LTS Gap .045, AC FR5LS Gap .035, Rapid Fire #5 Gap .045.
Fuel Requirement: Unleaded Premium 92 Octane
¹Ignition Timing: 12° BTDC @ 800 RPM, 36° total @ 3,200 RPM with vacuum advance disconnected.
Max. Rec. RPM: 5800 rpm
Old Jan 6, 2005 | 08:19 PM
Roadster71's Avatar
Roadster71
Thanks for the information.
Old May 19, 2025 | 03:48 PM
Roman Bulldog's Avatar
Roman Bulldog
1st Gear
https://www.crateenginedepot.com/pdfs/SB_zzengine.pdf
https://acrobat.adobe.com/id/urn:aaid:sc:VA6C2:99a768d9-ae12-4b47-b193-1321b638ec79
I think you will find the above links very helpful. Let me know if you have any questions
Old May 19, 2025 | 03:51 PM
Roman Bulldog
1st Gear
https://acrobat.adobe.com/id/urn:aai...3-1321b638ec79
SB_zzengine.pdf
Old May 23, 2025 | 04:28 PM
TKX 5-SPEED C3's Avatar
TKX 5-SPEED C3
I have a question about your time machine.
Old May 23, 2025 | 04:35 PM
TX427C3's Avatar
TX427C3
Active Streak: 90 Days
St. Jude Donor '06-'09,'22,'25
Originally Posted by Roman Bulldog
Time machine no doubt... nothing like adding to something that has been answered a myriad of times over the twenty years since this was asked!!
But there will still be responses from those masters of diatribe that we all recognize LOLOL
Old May 23, 2025 | 04:47 PM
TKX 5-SPEED C3
Good one Chakeesh!
Old May 23, 2025 | 05:31 PM
C3DeedlyDee's Avatar
C3DeedlyDee
ZZ4 is ZZ3+1
To ZZ3 vs. ZZ4
