^##*^$@# clock restoration...
Old Jan 7, 2005 | 09:04 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Default ^##*^$@# clock restoration...
Get home tonight and the new rebuild kit for my clock is here. Get everything out and read the instructions. In big letters they read:
You can't do a conversion yourself if the clock is a westclock........
That's what I have.
I suppose I'll call 'em Friday and check options. A clock is a fairly minor thing but I'm a little kid when it comes to getting shut down, even on little shet...
Old Jan 7, 2005 | 10:24 PM
68/70Vette's Avatar
68/70Vette
Iwonder why they didn't let you know that before you ordered the kit???
Old Jan 7, 2005 | 10:39 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
I feel bad about this because I may have helped influence you to go this route. Seems like the kit I used had extra parts (gears) that were used in other models...
Edit: I just found my kit (I save too much crap). It was made by ISI of Roscoe, IL. You are correct, it was made for "Borg" clocks, not Westclox. Looks like they have some other options available including sending the clock in for rebuilding. I wish I could remember the thread, it was a couple years ago. Said something about cleaning the winding motor switch contacts which will correct the operation of the original clocks...
Old Jan 8, 2005 | 12:13 AM
desi's Avatar
desi
http://members.aol.com/jjneyjr/clock/grepair2.htm
Does this help?
Old Jan 8, 2005 | 11:40 AM
Avette4me's Avatar
Avette4me
I'll likely call the Borg number on Monday...I did the cleaning process on desi's post and the clock works, after closer inspection just has some bad gears.
Since the original clock is quartz, I'm considering using the gears that came in the kit...I'll see what they say Monday..
BTW, Big Fish - no need to feel bad about it - I didn't know there was a difference either and didn't know I had westclox 'till I read the borg instructions..
Old Jan 8, 2005 | 12:03 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You might want to check these folks out.
http://www.clockwks.com/CLOCKWORKS/The_Clock_Worx.html
I have a quartz movement in my car now that works just fine but being an NCRS nut I acquired another original clock for my 71 and sent to the Clockworks. For $69 they installed a NOS movement and guaranteed it for 18 months. They also do quartz movements....I highly recommend them.
Old Jan 8, 2005 | 12:07 PM
vettfixr's Avatar
vettfixr
Lonnie, I thought you couldn't tell time.
Old Jan 8, 2005 | 12:14 PM
Avette4me's Avatar
Avette4me
Thanks...I'm in heavy into NCRS (not correctly restored corvettes ) as well....
All kidding aside, unless someone changed mine, the face of the westclox even says "qaurtz" on it...I supose I'll get a little smarter on Monday...
Old Jan 8, 2005 | 12:17 PM
Avette4me's Avatar
Avette4me
....well fine, your right..but I really, really like to watch that little orange thing go around in circles...
Old Jan 8, 2005 | 01:42 PM
barkingowl's Avatar
barkingowl
Cruise-In IV Veteran
Cruise In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Lonnie have you thought about putting a sundial on the dash?
Old Jan 8, 2005 | 01:52 PM
Avette4me's Avatar
Avette4me
I put one on the hood for a while...but when I changed directions, I thought it got late and fell asleep at the wheel...
To ^##*^$@# clock restoration...
