Need some things dated please
Old Jan 11, 2005 | 07:36 PM
majic1984's Avatar
majic1984
Default Need some things dated please
Alright, I pulled this up on the drivers side of the block by the distributor:
Casting number
Found this on the passenger side of block:
Date number???
also found these:
http://members.***.net/gdeb/Pictures%20048.jpg
http://members.***.net/gdeb/Pictures%20054.jpg
http://members.***.net/gdeb/Pictures%20059.jpg
http://members.***.net/gdeb/Pictures%20061.jpg
Could someone please help me date these items, or give me some sort of information about them?!
Thanks,
Michael
Old Jan 11, 2005 | 07:49 PM
captainmorgan's Avatar
captainmorgan
Judging by the head casting number it is 72'-73'.
Old Jan 11, 2005 | 08:05 PM
majic1984's Avatar
majic1984
Where could I find more date information on the engine?
Thanks,
Michael
Old Jan 11, 2005 | 08:08 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
From mortec.com:
3970010....302.....69....4...Z-28 Camaro
3970010....327.....69....2...Trucks and industrial
3970010....350...69-80...2 or 4
Heads:
3998993....72-73...307/350......75cc chambers
Old Jan 11, 2005 | 08:11 PM
majic1984's Avatar
majic1984
Isn't that the date number on the passenger side of the block that I took a picture of (the one that was behind the distributor) why would it say something like B 1 88, when clearly everything is pointing to it being something between a 68 and 77???
Old Jan 11, 2005 | 11:45 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
It reads "B 18 8", OR Feb 18, 1968(or possibly 1978 if that casting number #3970010 was still being used in '78(which I'm sure it was).
Old Jan 13, 2005 | 03:53 AM
stingr69's Avatar
stingr69
Heads are from '73, Block is probably from '78 as the "010" block was not in production in '68 or '88.
If you had pics of the engine suffix code stamping from the front passenger side block deck we could tell you more. If it has a 3 letter suffix, it is a '70's block. Generaly, If the suffix begins with a "T" it was probably originaly for a "truck" and probably has the 4 bolt mains. If the 3 digit suffix begins with a "C" it is probably a 2 bolt main "car" block unless it was for an L-82 Vette originaly.
This block looks to me to be a 4 bolt main but that is based on an obscure undocumented observation of the tapped boss on the top of the bellhousing mounting surface. Tapped top hole = 4 bolt main. This is not carved in stone anywhere but you are free to quote me during a bench minutia racing session any time.
-Mark.
To Need some things dated please
