Lowering?
Old Jan 14, 2005 | 01:20 AM
74FLCONV's Avatar
74FLCONV
Default Lowering?
My car needs to be dropped slightly. Planning on cutting the front springs as per other posts here.
Question on the rear. Will longer bolts alone lower the car 1" or so? My rear spring looks like crap, so I will probably replace it while under there. Can using a different spring lower the car?
D. Ocean
Miami, FLA
Old Jan 14, 2005 | 11:29 AM
etech152's Avatar
etech152
I also need to lower my Rear by about 1 or 2 inches. My local shop told me that there is a longer bolt they simply install which lowers it by 1". I plan on doing this sometime in the future. My front is ok. Lowering my rear 1 or 2 inches (full tank or not) will make the Car look even both front and rear. I'm wondering what it may do to the handling of the car??
Old Jan 14, 2005 | 11:38 AM
VBP's Avatar
VBP
St. Jude Donor '07,'13
D. Ocean
Miami, FLA
74FLCONV,
Yes, longer spring bolts will lower the rear of your Vette. The stock GM spring bolts were 6 1/2" long. We offer an 8" long grade 8 spring bolt for rear ride height adjustment. Depending on rubber or poly bushings it would run for about $ 26.96 - $ 22.46. As for your front coil springs remember that when cutting them down 1/3 of a turn equals 1 inch of ride height so don't over shorten.
Tony
VBP
800-237-9991
Tony@vbandp.com
Old Jan 14, 2005 | 11:44 AM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
I recently changed my rear spring bolt cushions from rubber to polyurethane and that added height. The polyurethane does not contract like rubber.
So, I am going back to rubber cushions and longer bolts.
I once read here doing this might throw the camper angle out of whack. Not sure if "camper" is the correct name.
Old Jan 14, 2005 | 12:29 PM
Kid Vette's Avatar
Kid Vette
Just make sure you don't use longer than 8" bolt or you'll risk having the spring end puncture the tire sidewall. You can use a 9" bolt with 17" wheels.
Old Jan 14, 2005 | 12:46 PM
munday's Avatar
munday
i think u mean camber
Old Jan 14, 2005 | 10:14 PM
74FLCONV's Avatar
74FLCONV
Thanks for the replies.
Will a different spring change ride height or is it all in the bolts?
D. Ocean
Miami, FLA
Old Jan 14, 2005 | 11:05 PM
i885744's Avatar
i885744
If your old spring is old and sagging it will certainly lift the back of your car up to where it belongs. The fiberglass springs tend to lift the car even more than a new stock rear spring. I have a fiberglass monospring from vbp, and the 8" lowering bolts also from vbp and its just about perfect for my tastes.
This ia 275/60/15 tire...
Old Jan 14, 2005 | 11:11 PM
Cali,68,L-79's Avatar
Cali,68,L-79
It's a cinch. I droped my front from 28 to 26" and the rear from 28 to 26.5" all within a day. the VDB 8" bolts are simple and straight forward even for a Marine. the front springs are more tedious but I'd caution to undercut and see where you settle out rather than cut too much and be *** out. IM me if you have questions.
David
Old Jan 14, 2005 | 11:47 PM
DropTopBigBlock's Avatar
DropTopBigBlock
"Lowering my rear 1 or 2 inches (full tank or not) will make the Car look even both front and rear. I'm wondering what it may do to the handling of the car??"
lowering the car also lowers the center of gravity, which is a good thing. you may not want to make it look completely even front-to-back, though; leave a little more room in the back for the spring to compress when you stand on it, since the back tends to move around more than the front. an inch or so difference should still look okay, without giving you the "ghetto wedge" high-rear-low-front look.
Old Jan 14, 2005 | 11:58 PM
74FLCONV's Avatar
74FLCONV
Originally Posted by i885744
Can the excess threads be cut-off the bolt once everything is in place? That looks like it could jab the sidewall.
D. Ocean
Miami, FLA
Old Jan 15, 2005 | 12:03 AM
i885744's Avatar
i885744
I don't think so, the picture is kind of deceptive, I can easily fit my hand between the bolt and the tire. I'm not worried at all.
Old Jan 15, 2005 | 07:17 AM
73jst4fun's Avatar
73jst4fun
D. Ocean
Miami, FLA
D, Get in touch with Tony of VB, He'll set you up correctly, if your still running with the stock front coil springs you can replace them with the 460's and a new 330 mono spring in the rear and 8" bolt kit will be a big differance in the ride and handling......go TR South....
Old Jan 15, 2005 | 09:14 AM
74FLCONV's Avatar
74FLCONV
Thanks...Go Indians.
D. Ocean
Miami, FLA
To Lowering?
