Winter Storage
Old Jan 14, 2005 | 12:23 PM
gr8whte's Avatar
gr8whte
St. Jude Donor '05-'06-'07-'08
Default Winter Storage questions
both the vettes are in storage and the battery taken out, checked to make sure the ant-freeze was gonna keep the block from freezing, is their anything i might have over looked? is their something i should do to them while they are in storage? thanks guys
Old Jan 14, 2005 | 01:08 PM
kens 80's Avatar
kens 80
Depends on how long your going to not start the engine or move car. For a long perior of time I would have 1. Changed oil and filter, greased all fittings. 2.Placed Jackstands under suspension to remove weight from tires to prevent flat spots. 3. Remove spark plugs , spray a little Marvel oil in each clyinder turn over a few revs, replace plugs. 4. Put a fuel stabilizer in fuel tank . 5. Either run engine till some of the stabilizer gets into carb or disconnect fuel line to fuel pump and run car untill the carb runs dry. 6.Top off all fluids 7. Check anti freeze. 8. loosen fan belts. 9. Remove battery and keep charged with a battery tender. 10.Wax body, clean interior, if leather apply leather treatment. 11. Seal all weatherstrps and rubber with favorite saelant. (Amor -all). 12. Put desecant bags in interior to absorb moisture. 13. Cover car.
This might seem like a lot of work but you asked for the best way.
Old Jan 14, 2005 | 01:31 PM
gr8whte's Avatar
gr8whte
thank you very much, i'll be doin the majority of that on sunday, cant do it saturday cuz the jets play the steelers at home GO STEELERS!!!!
To Winter Storage
