Fuel return line size?
Would there be any advantage in routing the fuel return line from near the carbureter back to the tank vs. running it from just the pump back to the tank?
Thanks for any help.
NO, the way I understand the f/p and the lines is very similar to fuel injection, in that the surplus fuel is returned to tank,
the fuel pump is actucated by a lever off the cam drive, so it has peaks and valleys, pressure wise, just like valve openings and closings, to the peaks are pressure releived and returned to the tank, this to keep the floats/seats from being forced open during idle or light throttle operation...it's a pressure relief system, really....
now I"m not sure why some very early cars didn't need/have such a system from the factory....maybe a chem change in gas?? I dunno....
you block that return line with say a vice grip, and watch the carb flood out shortly after....
pulling off the top of the carb is highly unreliable in that it's not a pressure area, and so would be too dependant on cornering, braking,...car dynamics....and of course....
leaking....damn carbs have enough problems with that, without adding more complications...
GENE
GENE
I had the same question. So if you can not route the line from the carb, where should you route the return line from? fuel pump?
The line is 1/4 right?
THanks,
Joe
Yeah, I think it is 1/4".
