The Devil clock
Old Jan 18, 2005 | 12:01 AM
Cali,68,L-79's Avatar
Cali,68,L-79
Default The Devil clock
Okay most of you know I removed the dash and replaced guages fixed this or that and afterwards the clock stopped then started for no reason. Well today I put in 2 new chrome ventilation ***** and for safety sake with wires about I disconnected the battery and guess what.............the clock kept ticking for about a minute! Battery was disconnected, I mean the positive battery clamp was no where near the positive post and it kept going. Either I have residual power somewhere or the car's got a UPS.
Old Jan 18, 2005 | 12:05 AM
olouieo's Avatar
olouieo
Old Jan 18, 2005 | 12:09 AM
81' Corvette Guy's Avatar
81' Corvette Guy
Isn't the clock an electromagnetic quartz set up..pulls juice to charge the movement..then keeps time..will pull juice when it needs it again??? Thought this was what the slow drain on the batteries was all about? Just a thought..thanks! Joe!
Old Jan 18, 2005 | 03:43 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Yeah what he said, or you just got a good flux capacitor!
Old Jan 18, 2005 | 05:49 AM
theandies's Avatar
theandies
Does your clock's second hand "tick"? What I mean by that is does it stop between seconds? If it doesn’t then it is probably been rebuilt with a quartz kit at some point. I think all your seeing is a capacitor discharging. I don't believe you would see that with the original mechanical setup.
Old Jan 18, 2005 | 08:00 AM
rrent's Avatar
rrent
I put a new quartz clock in not long ago --- while reasearching redoing my original I learned it is set up in a fashion that the power actually "winds" the clock and then when it winds down a contactor comes in contact and "re-winds" it again --- if you search under topics posted by me you will see all the info others posted. Sound like you just saw your winding down.
Good luck --- if all else fails gets a cross and maybe even a wooden stake and wear some garlic around your neck --- that sould keep you safe
Old Jan 18, 2005 | 08:12 AM
80Xflags's Avatar
80Xflags
Don't worry, your clock is not possessed. As the clock unwinds it physically brings together two contacts that briefly energize a solenoid, which, when it recoils will rewind the clock. This cycle happens every 1-2 minutes, so if your clock is the old mechanical style expect it to run for 1-2 minutes independent of any power source.
Old Jan 18, 2005 | 11:22 AM
Cali,68,L-79
I think your right. This is the original clock.
Old Jan 18, 2005 | 12:29 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
While I believe this is correct, you might want to sacrifice a chicken over the clock just to be sure. The wooden stake, while possibly effective, will damage the clock.
Old Jan 18, 2005 | 01:41 PM
Cali,68,L-79
Old Jan 18, 2005 | 02:56 PM
Z-man's Avatar
Z-man
Similar experience - My clock hadn't run in 20 years. One day, a few years ago, I was sitting in the car doing nothing and it was real quiet. Suddenly - click! - the clock decided to start running.
[insert Outer limits guitar music...]
Old Jan 18, 2005 | 04:29 PM
DropTopBigBlock's Avatar
DropTopBigBlock
Friend of mine had an Austin Healey . . .driving along one day when BANG! the radio comes on. Never worked before. . . keep hoping that'll work for mine . . .
Three cats and a chicken!
Old Jan 18, 2005 | 07:53 PM
checklst's Avatar
checklst
The clock has a loaded spring that will run about 1 1/2 min, then the contacts touch and the spring loads again, repeat a few 100,000 times and something will burn out or break.
Old Jan 19, 2005 | 01:09 PM
GUSTO14's Avatar
GUSTO14
Actually the contacts are little more than the equivalent of a set of points. Many times they will weld themselves together as a battery runs down and doesn't have enough power to "snap" the points open. (Actually it's more of a bond and less of a weld.)
The easiest thing to do is check that the points operate, and then use a fine fingernail file to smooth them. I've gotten more than a few older clocks to work this way.
GUSTO
To The Devil clock
