is there a web site where i can look up old GM part numbers??
I wanted to double check the part number of an intake manifold that i've just bought, to see if it's a '79 L-82 manifold (which it what i think it is).
And is the 'part number' the number cast just behind where the carb mounts? .... it says GM CFM, then underneath '14033056' ... does that sound right???
yep Patrick.. i think that last digit could well be an '8' and not a '6' ... it's a bit worn. Looks like you've solved the mystery for me! .. the intake is pretty similar to the '79 one but it's missing the hole for the choke tube (as pictured in paul's photo).
Thanks for your help!
..by the way, what is an L-81? cant see it in my black book?
The LG-4 was the 1980 305cid, 180hp certified for California. The 350cid did not meet emissions standards in 1980 for that State. The L-81 (350cid, 190hp) was the only engine offered in 1981 and it did meet California standards. I am not familiar with that 1981 aluminum intake but it may have had some modifications for the new computer command control (CCC) emissions/engine management system (timing and air-fuel mixture).
