shorter rear spring
Old Jan 22, 2005 | 10:37 PM
77 vette's Avatar
77 vette
Default shorter rear spring
I've been looking at my rear end and wheel well area to find the widest rim that will fit inside, I will be going with Van Steel offset trailing arms before there sale ends, my biggest clearance problem is with the e-brake bracket (this will be moved on the new t/a's) and the outboard ends of my spring, I think there are double offset trailing arms but you have to go with a shortend spring, does anyone know where I could find more info on this? Thanks.
Old Jan 23, 2005 | 04:22 PM
redc3's Avatar
redc3
by no means am i an expert here, but was informed by member you can shorten exsisting spring. its spring steel of course so dont use the blue wrench. i know for a fact that almost any fab shop can punch a new hole in this metal, as it is extremely hard to drill. good luck
Old Jan 23, 2005 | 04:29 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
VBP will make a short spring i was tling to him at the corvette show yesterday
Old Jan 23, 2005 | 04:40 PM
73jst4fun's Avatar
73jst4fun
VB Products sells shorter springs, just talk to Tony and he'll set you up correctly...
Old Jan 23, 2005 | 06:56 PM
77 vette's Avatar
77 vette
I looked hard at mock drilling a new hole in my old spring and found that I would have to move the hole to far inboard to still have wall thickness. I think I only need about 1.0" at each end to clear and could go with a new steel spring. I would really like to get Vette brakes #330 rear spring shortened but how will it align with the trailing arm holes?
Old Jan 23, 2005 | 07:56 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I'm getting a 1.5 inch shorter VBP spring (3/4 inch each side) and my tires will fit under the fenders (ET Street 28 x 13.5 -15) which is about the same size as 325/50R15 tires...
Old Jan 23, 2005 | 08:14 PM
flynhi's Avatar
flynhi
VB sold me a shortened composite spring a few years back. They started with a 315 and shortened it 1.5" on each end. New rate was about 340.
Old Jan 23, 2005 | 08:25 PM
norvalwilhelm's Avatar
norvalwilhelm
Spring steel is only 1045 steel with a hardness in the low 40s. It can be drilled easy enough if you use low speed, a sharp drill and lots of oil. IT is really no problem. Only do one end, not both and then move the center 3/8th hole until it is mid way between the 2 holes. You need a 3/4 inch drill bit. A prentice drill is one with 3/4 bit but 1/2 inch shank.
I have done them in the shop
Old Jan 23, 2005 | 08:54 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
I can get you one when you buy the double offsets. I have them as well.
Old Jan 24, 2005 | 04:35 AM
Solid LT1's Avatar
Solid LT1
Guldstrand Engineering sells a shortend main leaf only for about $100. I have one on my LT-1 and they work really well. Here's the link: http://www.guldstrand.com/spring.htm
To shorter rear spring
