solid motor mount question..
Old Jan 24, 2005 | 06:38 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Originally Posted by DropTopBigBlock
with solid motor mounts, doesn't that also lower the engine in the car, giving you a lower center of gravity?
I don't know.. I'll check.. Looks the same height to me... If it would sit lower would be great because I coult install a taller intake
Old Jan 25, 2005 | 10:51 PM
zZArAZz's Avatar
zZArAZz
I heard stories of solid motor mounts turning the middle drivers side cylinder bores to ovals.
I am no expert but i would go with poly mounts with backup chains to the frame on the drivers side, or if you need the solid connection then a front motor plate. I have poly mounts on my 505 bb and am attaching chains before it leaves the garage.
Old Jan 26, 2005 | 01:29 AM
71coupe's Avatar
71coupe
I have VB&P safety mounts on my car. They have the rubber insulator, but they are designed to stay together with a steel surround in the remote chance the rubber seperates.
http://www.vbandp.com/detail.aspx?ID=618
