solid motor mount question..
Old Jan 23, 2005 | 06:26 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default solid motor mount question..
I bought Moroso solid engine mounts for my engine install...
They are supposed to fit '63 - '82 Vettes...
Well - they seem to fit with only one issue (which might not be an issue)...
Well - the motor monts that bolt to the block would be big enough to fit a 1/2 inch bolt to mount them against the mount on the frame. However - the motor mounts on the frame only fit a 7/16 bolt... Is it ok that there is some play??
Old Jan 23, 2005 | 06:59 PM
ZD75blue's Avatar
ZD75blue
Ttt
Old Jan 23, 2005 | 07:03 PM
john1977's Avatar
john1977
why would you want to use solid mounts? these cars if you plenty of feel without solid mounts.
Old Jan 23, 2005 | 07:06 PM
Schmucker's Avatar
Schmucker
Why not drill it out?
Old Jan 23, 2005 | 07:10 PM
GrandSportC3
Well - I don't think that it's safe to run rubber or poly mounts with the kind of HP that my new setup has...
Old Jan 23, 2005 | 07:11 PM
GrandSportC3
I could do that if I'd know if that's the right thing to do.. Maybe there has to be some play..
Old Jan 23, 2005 | 07:32 PM
PatsLs1vette's Avatar
PatsLs1vette
Ive been running moroso solid motor mounts for years,and i have no play,bolts fit snug through them.
Old Jan 23, 2005 | 07:41 PM
GrandSportC3
Do you know what size bolts you are using (the bolts that connect frame and engine mounts)???
Old Jan 23, 2005 | 07:45 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
if i'm following you correctly you are saying the new mounts have a larger hole in them then the frame mount. i'm sure the holes that mount to the block are also slightly larger then the bolt you are going to put throughthem....this would allow for some adjustment and movement...sounds ok to me...
Old Jan 23, 2005 | 07:54 PM
GrandSportC3
I just figured out why the holes are different size...
The correct mount for Vettes is Moroso part number 62530... and I got part number 62560.
The Summit website says that 62560 mounts fit Vettes.... but the Moroso Website says that only part number 62530 fits Vettes...
Will try to get the correct mounts tomorrow...
Old Jan 24, 2005 | 07:51 AM
PatsLs1vette
Yeah i tried the other ones before and then ordered the right ones,fit alot better.
Old Jan 24, 2005 | 08:08 AM
isosceles's Avatar
isosceles
Good catch!
So i take i the motor is dangling from the hoist?
Old Jan 24, 2005 | 08:23 AM
GrandSportC3
Yes, the motor is tangling in the air with the tranny attached..
Can't really put it somewhere with the tranny attached...
Old Jan 24, 2005 | 09:02 AM
mrvette's Avatar
mrvette
Well, you know, that depends on the angle of the dangle...
GENE
Old Jan 24, 2005 | 10:34 AM
norvalwilhelm's Avatar
norvalwilhelm
I don't know if you have the ability to tilt the engine when installing because your other post pictures just show 2 chains but the ability to tilt really makes life easier.
I also run alot more horespower then you without a problem with poly motor mounts. I found solid mounts cause a vibration at idle. I know you don't care about this but I found it annoying sitting at a light.
Old Jan 24, 2005 | 10:43 AM
GrandSportC3
I know that you have a lot more power than I have, but do yo run slicks and a transbrake? Lot's of power without traction is by far not as violent on the drivetrain than big slicks and a trans brake..
Old Jan 24, 2005 | 12:02 PM
norvalwilhelm
Your right, I use to run slicks all the time but after tearing the transmission up 3 times I gave up.
To solid motor mount question..
Old Jan 24, 2005 | 12:12 PM
bobs77vet's Avatar
bobs77vet
just out of curiosity i measured my old motor mount slot....it was 7/16 x approx 3/4...sounds like ordering the right part was the thing to do...
Old Jan 24, 2005 | 12:17 PM
GrandSportC3
I'm mostly concerned about the transbrake launches.. The shock of the transbrake on the drivetrain is pretty violent..
Old Jan 24, 2005 | 01:29 PM
DropTopBigBlock's Avatar
DropTopBigBlock
with solid motor mounts, doesn't that also lower the engine in the car, giving you a lower center of gravity?
