What A Difference Two Weeks Can Make
Old Jan 29, 2005 | 07:31 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default What A Difference Two Weeks Can Make
-20c and looking like the north pole
+7c and feeling like spring
I finally got the wheels turning and started the winter projects.
First one is remove all bose and replace with something from this millenium
Then i will be ready for the poly bushing project
Old Jan 29, 2005 | 07:59 PM
JackDidley's Avatar
JackDidley
New "garage" is looking good. Watch out that snow can be back though .
Old Jan 29, 2005 | 08:12 PM
MyOtherCar's Avatar
MyOtherCar
Veteran: Marine Corps
Don't know if you paid attention or not, but you have a lot of moisture on the ground inside your portable tent. As the snow melts during the warm days of winter and it gets trapped in that tent thing, you'll be wishing you just left your car out of doors. I'd suggest leaving a vent opening and run some sort of circulation fan in there. The moisture has to evaporate or you'll notice corrosion start up on everything metal, like alternator, etc. Not a pretty picture.
Old Jan 29, 2005 | 11:45 PM
ynk1121's Avatar
ynk1121
Same here. (the igloo on the left is my vette and right is my camaro) 24 inches of snow and a temperature in the negatives last week makes todays 36F feel tropical.
Old Jan 30, 2005 | 12:14 AM
cv67's Avatar
cv67
St. Jude Donor '05
Man, I don't know how you do it...I'm crying cold at 60!
Must drive you nuts to see the vette buried like that!
Old Jan 30, 2005 | 01:57 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I just started on my bushing install tonight. Took the entire front suspension out.
Getting these old bushings off is going to be a bitch. They're fused to the aluminum. When the control arm rotates, it tears the bushing internally rather than sliding on it.
I've had the parts sittin around awhile and today decided what the hell, lets start unbolting ****. If you need any advice on it, gimme a ring. Have fun figuring out how to get the passenger side upper a-arm.
Old Jan 30, 2005 | 02:02 AM
bogus's Avatar
bogus
yo, Agent - that tent looks almost professional. There was something lovable 'bout last years tent, tho...
You might want to install a circulation fan. If I had stayed east, I was going to get one of those inflatable tent thingys.
CentralCoaster - the tool you need is a torch. Melt those bastards out.
Old Jan 30, 2005 | 03:34 AM
AGENT 86's Avatar
AGENT 86
I'm sure you will be hearing from me Kevin
Old Jan 30, 2005 | 03:35 AM
AGENT 86's Avatar
AGENT 86
Good point, thanks. I think i will leave the far end open somewhat to vent.
Old Jan 30, 2005 | 09:11 AM
Nathan Plemons's Avatar
Nathan Plemons
Actually the tool you need is a shop press. It'll stink a whole lot less and doesn't run the risk of changing the crystal structure of the aluminum with the torch. Remember that piece of aluminum has very specific properties for that application.
Old Jan 30, 2005 | 12:27 PM
mid life 90's Avatar
mid life 90
Crazy isn't it. I thought we were gonna float away down here.
The kids have seasons passes for hemlock and guess what, no snow
Old Jan 30, 2005 | 06:32 PM
jvette44's Avatar
jvette44
This has been 1 bitch of a winter! So far I've driven mine 4 times to work this week!,last time I drove it was before Xmas!! Hope the snow and cold are gone for good!!!
Old Jan 30, 2005 | 06:42 PM
Caboboy's Avatar
Caboboy
You're tellin' me! I don't think it got to 65 today..............I damn near had to put long pants on
Old Jan 30, 2005 | 06:43 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Dan, its a piece of cake! You have the know how to press those bushings out. If I can do it all with a 4 inch bench vise, a bunch of deep sockets and a 1 1/2 to 1/2 pipe reducer...... So can you.
Looks chilly up there.
-JRC-
Old Jan 30, 2005 | 08:12 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
I miss the excitement and suspense of last years garage. Now what do we bet on!?
+7 C....Maybe they should add a Tour event for late Jan in the great white north. At least make it interesting, I'm tired of seeing the guys go 20+ under for 4 days. I do like Leornard though, so I'm happy he found his way back to the top.
To What A Difference Two Weeks Can Make
