radio problem!!!
Old Feb 5, 2005 | 11:17 PM
Soonerfan19's Avatar
Soonerfan19
2nd Gear
Default radio problem!!!
recently my radio has been on the fritz first I started hearing popping noises coming from the speakers so I replaced speakers. still popping.
then the radio starts not receiving a signal antenna is up but now the antenna wont go up but some of the time it does and signal is in and out somebody please help!!!!
Old Feb 6, 2005 | 12:28 AM
blkblt97's Avatar
blkblt97
Factory Bose stereo? After market stereo? What kind of speakers did you replace?
Old Feb 6, 2005 | 12:48 AM
85 500 horse's Avatar
85 500 horse
If you have the bose, it's probably the amp(s).
Old Feb 6, 2005 | 12:50 AM
bogus's Avatar
bogus
not only should this be in audio, you duped by posting it here and in tech...
Old Feb 6, 2005 | 01:20 AM
85 500 horse
Look when this person joined the forum. It was just days ago. He probably has no idea how things work. Go easy on him. Your post reads like an admonishment. If I were on the receiving end, I'd be afraid to make another post for fear of another admonishment. Why not simply politely inform. I know I'd much rather read a reply in that fashion to one that chastises.
Old Feb 6, 2005 | 03:17 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
It's the amps.
You have two options, the hard way, and the hard way.
The hard way is to rip out all the bose stuff and replace all of it, and probably the speaker wiring too. You can't piecemeal it together with aftermarket stuff, its all or nothing.
The other hard way is to send the amps in for refurbishing, or find out what the typical parts to be resoldered are (its documented on here, but our search function is dead.) The R&R on those old amps is expensive, and that won't guarantee a working system.
Old Feb 6, 2005 | 04:24 PM
bogus's Avatar
bogus
It is an admonishment...
This is the 21st century... most every forum on this planet that is broken down into sections has rules about cross posting items, unless expressly permitted.
Besides, I had already commented in the C4 Tech thread, rather politely, then I see this...
Old Feb 6, 2005 | 04:41 PM
ddonzella's Avatar
ddonzella
I don't know< US soldiers dying in Iraq, Tidle wave kills 150,000 people,
Family tortures and starves 5 of 7 children....... New member post ends up in two places..........
Just my .02.
Old Feb 6, 2005 | 05:25 PM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
If it's factory, Bose, part of the problem could be your antenna relay. On the '96 it's located in with radio, behind the passenger seat. Don't know what year yours is, but the first thing to check would be all of the connections to the radio, the head and the antenna.
Old Feb 6, 2005 | 05:32 PM
CMYC4GO's Avatar
CMYC4GO
You can get new amps from MAD for about $125 each
Old Feb 6, 2005 | 06:05 PM
bogus's Avatar
bogus
Just my .02.
ah, but we must maintain an element of civil order when things all around are falling to pieces... point taken.
However, life is always full of worse cases...
Old Feb 6, 2005 | 06:16 PM
85 500 horse
There are several amps in the Bose system. If one or more in yours have failed, it will be costly to repair. When one of my amps died, I chose to replace the entire system with new front and rear speakers, an Mp3 player and an amplifier. I went for high-powered speakers, a top of the line Alpine Mp3 player and a fairly good amp. I also had them install a Viper alarm system at the same time. I paid $1,100 for everything. So once again, you get what you pay for.
Any competent radio installer will tell you that it's not easy to remove all the Bose components. It takes hours. If you choose to change your system, make sure you go to someone reputable as well as knowledgeable.
Old Feb 6, 2005 | 06:34 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
All anybody has to do is read this
http://forums.corvetteforum.com/showthread.php?t=881480
It's only been at the top for Lord knows how long.
To radio problem!!!
