Security Problems
Old Feb 9, 2005 | 10:43 AM
ddorlando's Avatar
ddorlando
Default Security Problems
My Security light comes on randomly...even when I am driving the car. The alarm goes off, when the security system isn't even armed. I have a brand new ECM...so I am wondering if it is a wiring problem. I saw some thread similar to this one...but any where the light would come on while driving. Please help if you can.
Also, does anyone know how to remove factory window tinting...the owner before me put on some aftermarket tinting. It started to peel, so I took it off...some of the factor tinting came off with it. I have tried razor blades, but had little luck.
Thanks in advance
DD
Old Feb 9, 2005 | 03:13 PM
Der Flieger's Avatar
Der Flieger
The tint film will come off if you do the following: Take Saran wrap and apply it to the film, smoothing it out as you apply it. Using a hair dryer, apply heat to the windows from the outside. Then pull the Saran wrap quickly,to pull it off. The window tint film should come off with the Saran wrap.
Old Feb 9, 2005 | 03:17 PM
Vett-eight-nine's Avatar
Vett-eight-nine
What do you use to take the adhesive off?
Old Feb 10, 2005 | 01:40 AM
85 500 horse's Avatar
85 500 horse
A product called goof-off will take off adhesive. Home Depot carries it.
Old Feb 10, 2005 | 08:41 AM
runner140*'s Avatar
runner140*
Default The product is....
Use Goo Gone. It removes adheasive, cleans stains on carpet and is a great all around cleaner.
To Security Problems
