Low Coolant Sensor
Old Feb 16, 2005 | 10:35 PM
ocrick's Avatar
ocrick
Default Low Coolant Sensor
I have an 89....how does this sensor work? Is it measuring temperature? Pressure? Also there is a "module" for this...how does it work?
Mine has been pretty goofy lately and I'm wondering if replacing the sensor would help.
Old Feb 16, 2005 | 10:48 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The sensor is a simple conductivity switch. When coolant drops below that level the light comes on.
To test the module, unplug the sensor and ground the wire. If the light still behaves badly, replace the module, else replace the sensor.
Old Feb 16, 2005 | 10:57 PM
weo89vette's Avatar
weo89vette
Mine comes on intermittently all the time. I've replaced the sensor. Where is the module located.
Old Feb 16, 2005 | 11:11 PM
kopbet89c4's Avatar
kopbet89c4
Bump... I need to know how to replace mine too. Just started coming on last week and yet the coolant level wasn't low at all! Hmmmm.....
Can anyone take pics and give steps in removal and replacement?
Old Feb 16, 2005 | 11:31 PM
NightFlight's Avatar
NightFlight
The coolent sensor is located on the passanger side of the radiator, approx 3-4 inches below the cap. Here's a pic ...
Once you locate it, you should be able to see how it comes out
Old Feb 16, 2005 | 11:46 PM
RONR's Avatar
RONR
Default Coolant Sensor
Is the coolant sensor an option or standard equipment. I have a 94???
Old Feb 17, 2005 | 02:32 AM
yellowlust's Avatar
yellowlust
Should be standard.
Old Feb 17, 2005 | 07:37 AM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
Coolant sensor on the 96 is on the overflow tank, on the passenger side firewall. I think the 94 is located there also. You can get to the sensor connector underneath the tank.
Old Feb 17, 2005 | 08:02 AM
NightFlight
Sorry, didn't know they moved it on the later model C4s
Old Feb 17, 2005 | 08:52 AM
corvette1989bham's Avatar
corvette1989bham
So what about the module?Where is it on a 89? BTW the most common fault of htis light coming on intermittantly is the sensor is mounted (l98's) HIGHER than the top of the radiator operating core (not heater core) if your coolant gets any air in it or is more than a half a cup low it will come on and off and you can top the radiator off till it overflows and not get it off....heres what you do...... Run the car to normal temp, if you have access to a ramp (like to change your own oil) run the front two tires up the ramp and put the front end of the car as high as you can, keep the car running with radiator cap off, idle the car up SLIGHTLY fill the coolant to the brim a couple of times, replace the radiator cap then take the car off the ramp. You allow the air to escape with the front end raised (car at angle) and can get a full coolant load.
Old Feb 18, 2005 | 02:27 AM
TIMSPEED's Avatar
TIMSPEED
Never thought of that trick.
BTW: I thought the Sensor operated on pH level's, maybe I'm wrong...
Old Feb 19, 2005 | 06:27 PM
ocrick's Avatar
ocrick
That is why I asked...if the sensor is a switch then they only needed a relay to turn on the low coolant light. Why a module? Does it have a timer which measures how long the switch is not grounded like in sudden acceleration?
Old Feb 19, 2005 | 10:20 PM
SunCr's Avatar
SunCr
Module is behind the bread box near the fuse panel. Easiest (at least for me) to access with the top of the dash off. Circuit is normally closed with the coolant at the correct level. If the light is on and the radiator is full, ground the harness lead and see if it goes out. If so, you need a new sensor. If not, the wire is open or the module is funky.
Module gets ignition power from the Gages fuse. Doubt it's blown or you would have other symptoms. Ground runs to the driver's side kick panel area. It's spliced into a ton of other stuff, so you would probably have other problems if it was out. The idiot light gets it's juice through the Security Indicator and is grounded by the Module. You allready know that that part is working because the light is coming on.
I don't know if the Module is available - Corvette Central might list it, but I haven't had any reason to check it - www.corvettecentral.com - Sensor is available. When I replaced the radiator, new GM, it came with it installed. Do get the air out of it when you fill it up as it (the air)will play havoc with the sensor and give you an intermittent light.
To Low Coolant Sensor
