Dash Cluster Bulb replacement
Old Feb 17, 2005 | 09:19 PM
Chewch87's Avatar
Chewch87
Default Dash Cluster Bulb replacement
I have a burned out bulb on the MPH side of my Dash Cluster. I want to replace all the bulbs that are behind those metal clip/covers. Are these bulbs stab locked , pushed, twisted or screwed in??? Is there a tool to remove them???Any suggestions on how to remove them without having one break or fall inside the cluster and cause a short.
My Haynes book says nothing about bulb replacements. Also where is the best place to buy them??? Thanks!!!!
Old Feb 17, 2005 | 09:33 PM
never2nd02's Avatar
never2nd02
5th Gear
If you buy the bulbs from a dealer your going to pay a bunch. There was a thread on this forum a few years ago about buying the bulbs and bulb sockets at pep boys. There not the same bulbs but they are close enough. I believe the bulbs were 687's. I replaced every bulb in my cluster with them and haven't had a problem since.
Old Feb 17, 2005 | 10:49 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
OK heres a suggestion;
Click on the Search tool pull down button
In the "Search By Key Word" Block
Type in "dash bulb" in the KeyWord field
Select Search titles Only
In the "Search in Forums" Block
Select C4 Corvettes 1984-96
Check ON the block, "Also search in child forums"
Then click on the "Search Now" button
Also look in the Tech Tips section
Lots of info here if you look for it
Old Feb 18, 2005 | 12:10 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Jr, here you go, post this. Less typing.
Old Feb 18, 2005 | 12:33 AM
Jloshotz's Avatar
Jloshotz
Push in. Auto barn has the 882 socket/bulb combo for 8 bucks
Old Feb 18, 2005 | 12:40 AM
JrRifleCoach
Your taking all the fun outta this
Old Feb 18, 2005 | 12:55 AM
Jloshotz's Avatar
Jloshotz
Old Feb 18, 2005 | 01:19 AM
Wayne88's Avatar
Wayne88
Here is the A-Z Dash Cluster Repair for '84-89 Corvettes.
It covers everything.
Its compiled by C4 "guru" Gordon Killebrew.
http://www.corvettemagazine.com/1999...ash/dashp1.asp
Old Feb 18, 2005 | 02:21 AM
JrRifleCoach
All kidding aside. ( ) I have a Word document that gives a complete step by step for repairing the digi-dash. Send me an email and I'll be glad to attach a copy.
BTW I just replaced the 882's with 194's in my 86's dash. Also fixed the short in there that keep turing off the lights. Its good reading.
-JRC-
Old Feb 18, 2005 | 09:59 AM
1Patriot's Avatar
1Patriot
The metal cover just pulls off. Use a piece of plastic tubing pushed over the blub for removal or rubber tipped forcepts. Replace with the same plastic tubing and when you want to remove the tubing, insert a small dowell into the plastic tubing to hold the bulb in place while you remove the tubing. The bulb has two wire type pins and are cheaper to buy at Wal=mart.
Old Feb 18, 2005 | 10:38 AM
HamCrab87's Avatar
HamCrab87
Default great info
My 87 is dark on the MPH side as well .... all LEDs work well (thank goodness). I have the new bulbs .... the front entry replacement is definitely esier than pulling the cluster.
My car is basically an unmolested example of how an 87 left the factory. No exotic throttle body, injectors, cams, etc ... just basic Vette charm. But ... on the downside it ws never shown or detaled, and tolerance for small nuisances (like dead bulbs and locked in ECM codes) exist. Sooooo ... I am undoing 18 years of dirt, grime, and neglect. Is it worth it? Hmmmmmmm .... lemme think .... DEFINITELY!
When done it will look like it rolled out of Bowling Green (except for the AM/FM/CD upgrade ..... gotta have the tunes). Stock Bose head unit is wrapped up snuggly in the garage. Replaced with the Pioneer Bose-compatable that I got from Zip.
HEED THE WARNING about keeping oil and grease off the bulbs. Halogens will fail quickly if not kept clean.
To Dash Cluster Bulb replacement
