I recently had some Flowmaster 50's installed on my '90 coupe and they don't quite have the sound I'm looking for. I want something with some more sound. Does anyone have the new Flowmaster Super 40's on an L98 out there? Are they similar in sound to the original 40 series mufflers? Thanks
I have the Flowmaster Super 40's on my '92 LT1. At first I still had the factory resonator on, but I recently had it replaced with an X-pipe. Sounds very healthy now. Getting a little resonance inside the car now, but only at certain RPM's.
Would I recommend them? Yes! Go for it. You'll be glad you did. These also have the black cases on them, not the silver. I would have just painted them black anyway.
You guys using 40's how about posting the part #'s your using, I'm looking at 40's also but havent decided, maybe you input on part numbers will push me over the edge.
Exactly. Are you using the center inlet/center outlet ones? If so, did you have to modify the rear exhaust bracket for them to work? I currently have the dual outlet 50's and I want a single center outlet for a 4" round stainless steel tip, but the exhaust hanger mounts right between the two outlets. I hope that made sense.....
On my 89 I had 42540 and added tips to it. Sounded good but if you have like a 2.59 rear end the resonace may drive you out of the car. I had 3.07s and it woud resonate around 1500 as I recall...
I'm using the 425501-L 425501-R They fit on the stock Y. I have a sound clip I can e-mail to you. I should add that I have gutted the cats and have the stock manifolds. Some resonance but not too bad for the mile I put on it a year.
Just installed these on my LT1. They sound great especially under wot but have just as much resonance at 2000 rpm as the orginal 40's do. This is on a stock a4 with 3.07 gears.
