Winter projects completed?
Old Feb 28, 2005 | 04:42 PM
LD85's Avatar
LD85
Default Winter projects completed?
What did you guys do?
I pulled the rear end for new 3:45 gears among other things, thought it was hard, but was something easily anyone can do.
Also, put in new crank & rod bearings (engine in the car) , new intake, pulled and reinstalled engine wiring harness.
Doohhhh, please move to C4 General
Old Feb 28, 2005 | 05:30 PM
Caboboy's Avatar
Caboboy
I did a little motor work.......
Old Feb 28, 2005 | 05:41 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
UNfortunately, my garage is under my house and my wife does not like the smell of fiberglass So I will have to wait until it gets a little warmer.
Old Feb 28, 2005 | 05:45 PM
Draven's Avatar
Draven
St. Jude Donor '14
Well, I lack the technical ability, so I talked to seeyaa and he's going to give me a hand with it this weekend. Car is stock outside of the exhaust right now.
I'm doing a SR, 219 cam, 1.6 Promags, melling lifters, CNCed 113 heads (good flow numbers vs. after aftermarket stuff), Hooker LTs and Y-pipe bolted up to the current flowmaster exhaust, and he's doing the tuning.
I play competition paintball, and a speedshop up in Manchester just sponsored us. This summer, he's dropping in a dino at his shop, so I'll have some ideas on what it pulls. : )
-Joe
Old Feb 28, 2005 | 05:57 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I started attacking the fuel delivery issue; got the new pump installed but snow and other issues have hampered doing the filter.
For spring I will be ordering the weather stripping kit.
Old Feb 28, 2005 | 06:34 PM
lensvet's Avatar
lensvet
St. Jude Donor '05-'07-'08
I had the plenum and runners powder coated.
It came out great.
Old Feb 28, 2005 | 06:38 PM
_twisted_'s Avatar
_twisted_
Well aside from spending a ton of $$ on parts nad assorted goodies, I havent had time to get nothing done yet, the newborn and the snow...
Old Feb 28, 2005 | 06:46 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
installed a new engine
Old Feb 28, 2005 | 06:51 PM
belmor's Avatar
belmor
New opti/radiator but that was more of a maintenece thing, we don't really have winter here lol
~B~
Old Feb 28, 2005 | 06:59 PM
-=Iron Mike=-'s Avatar
-=Iron Mike=-
nope. I still have to pop in a new slave cylinder and change out the plugs and wires. So much for a schedule, huh. My garage is so damn messy right now I can't move around to find my tools. :o
Old Feb 28, 2005 | 07:11 PM
bdvdvh7's Avatar
bdvdvh7
tires. new bf goodrich g force. good price too. local tire company, 695.00 for four. including tax and install. now a tune up next week, and i am ready to go.
Old Feb 28, 2005 | 07:29 PM
JackDidley's Avatar
JackDidley
I did long tube headers and fixed the power antenna. I'd do darned near anything to get into the 12s. (on real street tires) I think the antenna is going to do it.
Old Feb 28, 2005 | 07:51 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Better headers and exhaust, trans cooler, oil cooler, converter, more brake and suspension upgrades.... there's more, always more, so much more!
Old Feb 28, 2005 | 08:01 PM
lead foot 85 vet's Avatar
lead foot 85 vet
sent it in for a cowl hood jan 1.........they said one week......this week.....two months later......they siad the color doesn't match.......awwwww dam.........hope I get it by summer.
Old Feb 28, 2005 | 08:23 PM
mesteffen's Avatar
mesteffen
Replaced all the u-joints, new exhaust, new rear wheel bearings, new rotors, brake pads, flushed the brake lines, changed the gear oil in the six speed, changed the power steering fluid, installed door insulator kits,new window weather stripping on doors, painted the brake calipers, new ignition wires cap and rotor.
Old Feb 28, 2005 | 08:26 PM
LD85's Avatar
LD85
Holy cow, Vette owners must have boosted the economy all by themselves
Old Feb 28, 2005 | 08:59 PM
CF6873's Avatar
CF6873
I replaced the OPTI(and vented it), water pump, wires, plugs, coil, intake gaskets, fuel filter, axle U-joints, both rear hub assemblies, replaced the rear gear lube with Amsoil synthetic, replaced the ATF with Mobil 1, installed new Z51 Bilsteins,installed a 30mm frt bar,bought a Harbor freight trailer and modified it to haul my track tires to autocrosses and track days. Come on Spring
To Winter projects completed?
Old Feb 28, 2005 | 10:12 PM
rsafier's Avatar
rsafier
Replaced a dead Opti, electric water pump, DelTeq Opti-Direct, bigger better tranny cooler, VBP camber rods, ditched the EGR completely, no more A/C....
Still gotta fix the wiring on my AutoX trailer so I don't get pulled driving to my first event in April.
Old Mar 1, 2005 | 09:01 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
My list isn't long, but i'm still getting nowhere in a hurry.
Winter is over here, for the most and my car is scattered throughout my house. My stereo upgrade is turning into a complete disassembly
Old Mar 1, 2005 | 09:08 AM
Swirk's Avatar
Swirk
One word.....Supercharger.
Installed an ATI Procharger with Intercooler. I am just about done. Along with the supercharger were injectors, MSD-6AL, new stage 2 clutch and aluminum flywheel, AFPR and a chip tune.
Fixed the leaky intake manifold gasket and oil pan gasket. Replaced u-joints and every seal that I saw when I had everything apart.
Should be a good summer.
