help with plugs
Old Mar 2, 2005 | 07:40 AM
raw122's Avatar
raw122
Default help with plugs
i normaly do most stuff my self but these plugs look like a pain,i have a 93 with lt1 does any one have a write up on replacing the plugs
thanks for the help
Old Mar 2, 2005 | 07:57 AM
Kwikerthanu's Avatar
Kwikerthanu
St. Jude Donor '05-'06
I bought a plug socket and a geared wrench off ebay, made specifically for the LT1. Socket and wrench both new $29.95. I'll find his user name and give it to you. Has them on there most of the time.
Here's the url, http://motors.search.ebay.com/_W0QQsassZotto84
Hope this helps.
Old Mar 2, 2005 | 08:28 AM
runner140*'s Avatar
runner140*
Default This should be under tech/perf
You will get more replys on your question under C4 tech/Perf. Also use the icons on the top of the page and click tech tips.
Old Mar 2, 2005 | 08:57 AM
Gooseit's Avatar
Gooseit
I just changed the plugs on my 95 Coupe with the LT1 engine. They are not easy to get to but they can be done. I forget what the plug number is but the back plug on the passenger side is a bear to get to.
I used a spark plug wrench with a wrench fitting cut into the socket on the end and got it out, It took me approximately four hours to do the eight plugs. plus another four for the plug wires. good luck
Old Mar 2, 2005 | 10:26 AM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
I've been happy with one of these sockets I got off ebay.
Old Mar 2, 2005 | 10:37 AM
rws.1's Avatar
rws.1
I agree, the shortened plug socket works well.
Use it in combination with a swivel head gear wrench and you're set !
In a pinch it will work with a normal open ended wrench
Old Mar 2, 2005 | 10:45 AM
redwing76's Avatar
redwing76
thanks for the help
Man, theres just some things that I'm too smart or too stupid to do and a plug change on a LT-1 is one of them. It cost me $75.00 labor + parts.
Old Mar 2, 2005 | 01:06 PM
raw122's Avatar
raw122
thanks for the info so far i have a delteq kit so the wires are the easy part
Old Mar 2, 2005 | 09:06 PM
Chris_G's Avatar
Chris_G
St. Jude Donor '05-'06-'07
Cost me $427 for labor for wires and plugs...You got a good deal
To help with plugs
