Shifting problems with 91 6sp
I just purchased a 91 6 speed and having trouble shifting from 1st to second. Every other gear is real smooth. I know gm installed something to do with the light that comes on that says " 1st to 4th gear" on dash at various times. Is there something I can do or install or disable this device. Sometimes it will shift smoothly though from 1st to 2nd , It's not all the time. Does my rpms and shifting have something to do with this. I'm frustrated and in traffic is a pain too and could be dangerous as well.
Any help or advise would be much appreciated here.
Jack
Jack
The skip shift is part of the CAGS system installed on all 6 speed Vettes since 1989. It was installed to skirt the EPA/CAFE fuel requirements (get better mileage). If you can shift from 1 to 2 at any time, even when the light comes on on the dash, then the previous owner has already installed a CAGS bypass switch on the transmission. If the system were functioning, it would force you to go from 1 to 4 under low-speed, part throttle conditions (actually blocks out gate 2 and 3).
Depending on mileage and wear & tear, the syncros in the ZF 6 speed transmission start to wear down, resulting in harder shifting. Also, a poorly maintained hydraulic clutch system can also degrade the life of a ZF transmission. Typically, the life of a ZF 6 speed is around 80,000 - 100,000 miles; after that, it starts to wear out. Some preventative maintenance can prolong the life of the tranny, including:
- Change the transmission fluid. Use the Castrol synthetic motor oil (BMW M3 engine oil), available at BMW dealers
- Replace leaky/old clutch hydraulic master and slave cylinders
- Replace clutch fluid
I agree to a point with what 94Vette has to say, but for a few details....
** The oil you want is the Castrol TWS 10-60 - you will need 3 litres.
** The ZF, especially a black tag, is gonna last much more than 100k. I have 133k on mine...
** Don't be too quick to replace the hydraulics. Make sure they are not leaking first. GM has had a problem with those parts for a while now... if yours are weapy, but still ok, don't take that plunge right yet. I would replace the clutch fluid with Valvoline Synpower Brake Fluid. Great stuff!
** Read the C4 Tech FAQ! It's a sticky in C4 Tech.
FWIW, I have a "blue tag" ZF6, which is a remanufactured unit -- had it when I bought the car with 42,000 miles on it, and I have had no major problems other than a leaking rear tranny seal which was a $8 fix from NAPA .
