antenna doesn't retract
Old Mar 6, 2005 | 07:18 PM
BLKBTY's Avatar
BLKBTY
Default antenna doesn't retract
My antenna does not go down. I hear the motor running, but it stays up. I tried to add some lubricant and it still doesn't retract. How can I tell if I only need the antenna and not the whole antenna assembly?
Old Mar 6, 2005 | 07:34 PM
saniterium's Avatar
saniterium
I just got a new vette on Friday and have the EXACT same problem. The motor just runs but it won't go down.
Old Mar 6, 2005 | 07:38 PM
JackDidley's Avatar
JackDidley
Its operated by a plastic line (sort of like weedeater line). The line is broken. Its replaceable. I think the process depends on what year the car is.
Old Mar 6, 2005 | 07:39 PM
darryld_ca's Avatar
darryld_ca
if you hear the motor running, chance are alll you need is a replacement mast kit (avail at GM parts). Comes with instr and is very easy to install. I had same problem, and the toothed 'tail' (can't think of proper term) was broken off.
For the new vette owner, it is one of the cheapest things you are going to have to fix.....lol
Old Mar 6, 2005 | 08:57 PM
JCAIRE2's Avatar
JCAIRE2
To antenna doesn't retract
