Static in rear speakers
Old 03-10-2005, 09:50 AM
nyecon
Cruising
nyecon's Avatar
Default Static in rear speakers
The last few times I started my 86 coupe, I heard static from the rear speakers. It is more of a crackle than static, and stops within 20 seconds or so, or if I turn the radio off (original was replaced with a Kenwood by previous owner). If I get on the gas hard, the static returns for 10-15 seconds and then goes away again.
Does my amp need replacing or could this be a problem from another source like the plug wires, Battery Ground, etc.? I have ruled out a speaker problem, and the fronts work fine. Could the Kenwood have fryed the amp?
Old 03-10-2005, 10:57 AM
SilverBeast
SilverBeast's Avatar
St. Jude Donor '05
From your description it sounds like something external to the unit. Maybe an in-line (12 volt line to the radio) filter will fix it. Available from Radio Shack. It's strange that it only comes from the back speakers, but with aftermarket unit it's worth a try.
Old 03-10-2005, 11:05 AM
snoopdan
snoopdan's Avatar
I also have an 86, and that sounds like your amplifier is dying. No noise filter in the world will help you on that. Sorry.
snoopdan
Old 03-10-2005, 11:36 AM
JCAIRE2
JCAIRE2's Avatar
snoopdan
My '88 was doing that, was a bad amp at one of the speakers.
Old 03-10-2005, 02:59 PM
Perfusion
Perfusion's Avatar
Time to call Doctor Don's!
To Static in rear speakers
Quick Reply: Static in rear speakers
