Wheel Alignment Question...
Old Apr 5, 2005 | 10:09 PM
chimknee's Avatar
chimknee
St. Jude Donor '06
Default Wheel Alignment Question...
I seen post where members have asked questions or made comments about getting there corvette wheels aligned. However they talk about all 4 wheels. Over the years I have had numerous wheel alignments done, not so much on newer cars, but it has only been the front wheels. What is there about a 'vette that requires 4 wheel alignment? Does it have something to do with the suspension? Are most alingment shops aware of this? Thanx.
Vic
Old Apr 5, 2005 | 10:25 PM
DBL001's Avatar
DBL001
It has an independent rear suspension and....you would hope most shops are aware of this
Old Apr 5, 2005 | 10:31 PM
JCAIRE2's Avatar
JCAIRE2
on the vette, the rear wheels must be aligned first to set the thrust angle of the car, then the front wheels are aligned to the thrust angle.
Old Apr 5, 2005 | 11:15 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Thats what my chiropractor tells me too!
Old Apr 5, 2005 | 11:29 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
More vehicles than not require four wheel alignment these days.
Old Apr 5, 2005 | 11:37 PM
85 500 horse's Avatar
85 500 horse
If the alignment shop isn't aware of how to specifically align your Vette (front and rear tires separately), walk, no run away. Or, you may drive for a short time after your car has been aligned improperly and your tires will be destroyed. And as we all know, Corvette tires aren't the cheapest in the bunch.
To digress, I remember way back when, I had a Nissan Sentra and it had 13 inch tires. It cost about $100 to put tires all around. You can't even buy 1/2 a tire for a Vette nowadays for that price.
I wish I were in Kansas and was wearing red shoes so I could click them and make a wish to go back in time 20 or so years. Those prices back then were a bit more to my liking. Gas was about $.85 a gallon and you could get a real decent car for under $10K. Times sure have changed. And so did the way we do alignments.
I somehow had to bring this all together.
Old Apr 6, 2005 | 12:07 AM
rws.1's Avatar
rws.1
Ask around, find a good shop. Ensure they give you a print out of the before and after specs. Follow this link to VBand P. Tell the shop to use the advanced street settings for your year of Vette. they will help your cornering and virtually eliminate tramlining.
http://www.vbandp.com/instructions/h...ruct/align.htm
Old Apr 6, 2005 | 06:02 AM
pwoolford's Avatar
pwoolford
St. Jude Donor '08
I just had the advanced street spec alignment done and absolutely love it.
Old Apr 6, 2005 | 08:57 AM
~SlvrFox~'s Avatar
~SlvrFox~
St. Jude Donor '05
Thanks rws.1 I've been looking for this stuff.
Old Apr 6, 2005 | 09:31 AM
rightofway's Avatar
rightofway
the sears auto center gives the printouts and the alignment ran about a hundred dollars i think.
Old Apr 6, 2005 | 09:33 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Most vehicles on the road today (I didn't say most new cars) have a rear suspension that cannot be adjusted for alignment (solid axle).
The cars with more advanced rear suspensions (independant) can be aligned....our Corvettes are counted among that group.
Larry
code5coupe
Old Apr 6, 2005 | 10:31 AM
She Is Ruby Red's Avatar
She Is Ruby Red
Cruising
Default I haer you Dorthy
I can remember pulling into a station and it was 30 cents a gallon, full service. I was so ticked off I drove off and swore to myself I would never pay that much for gas. I was used to 25 cents a gallon and when they had a gas war 19 cents a gallon. The other day I filled the vette up for $2.30 a gallon. Two things are true we are not in Kansas anymore and it isnt 1972.
Old Apr 6, 2005 | 12:43 PM
70vert's Avatar
70vert
Banned Scam/Spammer
4 wheel allignments are very common: all FWD cars need to have a 4 wheel allignment.
Old Apr 6, 2005 | 01:54 PM
c4cruiser's Avatar
c4cruiser
All C4 rear alignment specs include camber and toe setting so any competent shop can do a good job on your car. Most all of the current alignment racks will provide a printout of the before and after settings.
Expect to pay around $75-90 for a good job. I would call around and ask tire shops or reputable repair shops about costs and any issues with bringing your own alignment specs.
Personally, I would stay away from Sears, Firestone and other chain stores unless you know first-hand about the quality of the work. There are places that will do what is called a "toe and go" where the front toe-in is set and they do nothing else and charge you for a full 4-wheel alingment.
Also beware of shops that tell you that you have to replace a bunch of components before they can do an effective alignment. Unless you know what condition your suspension components are in before you go for an alignment, you could wind up having unecessary repairs being pushed on you.
Old Apr 6, 2005 | 02:32 PM
2blklt4's Avatar
2blklt4
Last week i went to a shop that does aligmnents only...NOTHING ELSE!
I paid $150 for a computerized 4 wheel alignment.
They aligned the car with me seating in it!!
They spent 3 hours WORKING ON IT and got it perfect.
A month before that i paid $59 for an alignment to a generic tire shop and they were done in 10-15 minutes...
Print out before and after shows how much off my wheels were and thats after being aligned manually without a computer to a cheap shop!
If you live in So Cal i`ll be glad to give you the name and ph # of the shop. I WAS IMPRESSED
Old Apr 6, 2005 | 06:25 PM
chimknee's Avatar
chimknee
St. Jude Donor '06
Default Ok, great and thanx....
Hey, thanks to all of you who replied back. My 96 LT1 doesn't need one, but I was just curious.
Vic
Old Apr 7, 2005 | 12:09 AM
2HIP4U's Avatar
2HIP4U
You might also consider a 4 wheel alignment with you sitting
in the driver's seat. Only, however, if you're the main driver and rarely have passengers. I've raced FIAT's (road racing) and this is the alignment of choice.
To Wheel Alignment Question...
