Compression on a 91 L98?
Old Apr 6, 2005 | 08:48 PM
trevkris2's Avatar
trevkris2
Default Compression on a 91 L98?
What should the cold compression be on an L98 with 80K miles?
Old Apr 7, 2005 | 01:12 PM
trevkris2's Avatar
trevkris2
Anyone?? Send me some love here guys!
Sheesh...40 guys look at the post, and not ONE knows the answer to this?? Either that, or there's just more "tude" with the C4 crowd.
Old Apr 8, 2005 | 01:56 AM
Grace91's Avatar
Grace91
No “tude” with this crowd……
My Helms manual only gives pressures for an engine that is at operating temperature, with the spark plugs removed and the butterfly’s wide open. Crank each cylinder through four compression strokes.
No cylinder should be less than 100 PSI and the lowest reading cylinder should not be less than 70% of the highest.
Hope this helps.
Old Apr 8, 2005 | 10:16 PM
trevkris2's Avatar
trevkris2
Thanks for the help. Maybe there is life on this planet after all!!
To Compression on a 91 L98?
