"One to Four" ?????
Old Apr 12, 2005 | 10:21 PM
lpguthrie's Avatar
lpguthrie
Default "One to Four" ?????
Hey Guys and Gals... What is the dash light coming on "One to Four" mean?.... Does it have something to do with the idle speed? As always... Thanks in advance!
Old Apr 12, 2005 | 10:28 PM
TerryMathews's Avatar
TerryMathews
It's called CAGS, it's a system in your Corvette that prevents you from shifting into second or third gear unless you're at WOT.
Old Apr 12, 2005 | 10:32 PM
lpguthrie's Avatar
lpguthrie
Thanks Terry, What is WOT and Why is WOT??? Or should I say Why does it have this happen?
Old Apr 12, 2005 | 10:51 PM
teebee's Avatar
teebee
2021 C6 of the Year Winner - Unmodified
WOT= WIDE OPEN THROTTLE. It's GM's way to get you to be economical.
Old Apr 12, 2005 | 10:57 PM
lpguthrie's Avatar
lpguthrie
Thanks Guys< I knew you would know!!!
Old Apr 13, 2005 | 09:12 AM
Red Tornado's Avatar
Red Tornado
i would recommend defeating CAGS. its one of the easiest and best mods for a stock vette. its utterly annoying in everyday, in-town driving. $14 and about 20 mins. of your time should do it
here's one source for a CAGS plug (for the clean, non-Sanford & Son approach): http://www.madvet.com/shop?frame=1.721
Old Apr 13, 2005 | 08:49 PM
bdvdvh7's Avatar
bdvdvh7
i hate it too.... it can be annoying. i just don't have the time, tools, or ability to remove it from happening. i just i'll just get used to it. passengers in my car think i don't know how to shift!!!
Old Apr 13, 2005 | 10:28 PM
lpguthrie's Avatar
lpguthrie
Thanks Brad... I just ordered one of those parts, looks like an easy mod!
Old Apr 13, 2005 | 10:37 PM
Riks40th's Avatar
Riks40th
From: St. Louis, Mo......... 1993 Torch Red w/White Interior...2006-07 Bloomington Gold 2005-ZR1/C4 Gathering, 2001-2012 Funfest
If you are trying to shift before from 1st to 2nd before 1200 rpms and between speed of 12-19 mph the CAGS locks out 2nd and 3rd gear. If you don't unplug this at the transmittion, you could either hold the clutch in for about 2 seconds and you can actually go to second gear. Or, rev 1st gear alittle more before shifting. It is definitely a very annoying feature.
Old Apr 13, 2005 | 10:55 PM
JCD's Avatar
JCD
If the 1-4 shift light is coming on and you're shifting into 2nd or 3rd anyway, CAGS has already been disabled on your car. It is a very common mod.
I only say this because people ususally post "Why the hell is my car locking me out of 2nd gear!???"
CAGS forces you into 4th gear from 1st when your speed and throttle position (and engine temperature) are below certain preset specifications (if you accelerate slowly the light turns on, if you gun it, it doesn't).
If you're not sure if CAGS is disabled, accelerate slowly from a stop in 1st gear, at about 15 mph shift into 2nd, if you can't get the car into 2nd, CAGS is alive and well (try this trick a few times, sometimes the ZF6 can get stuck on a tooth). If you can you should cancel your order (CAGS can be bypassed in the chip or physically via a plug on the bottom of the transmission).
Old Apr 14, 2005 | 10:37 PM
lpguthrie's Avatar
lpguthrie
I'm not really sure what the part does other than maybe keep the connection clean and free of grit??? but it was only $20 with shipping and appears to be an easy install with the only problem as always... getting under the car! Thanks again everybody for all the info!
Old Apr 15, 2005 | 01:18 AM
yellowlust's Avatar
yellowlust
Since you already sent in your money to the poor catalog folks... I'm hesitant to give you this little freebie.
And btw, it's not WOT that deactivates the CAGS, it's more like 1500 rpm.
Of course all of this applies to 95 and older Vettes, newer ones do require a resister in the plug to fool the OBD II.
Old Apr 15, 2005 | 11:29 PM
mike2000's Avatar
mike2000
This is true but remeber that CAGS kicks in only after the car is warmed up.
To "One to Four" ?????
