battery changed
Old May 20, 2005 | 07:41 AM
86shark's Avatar
86shark
Default battery changed
I changed the battery on my 94 this past weekend, was not that hard but how did you guys loosen that bottom nut under the gill, grind down a wrench??? and the bolt on the tie down broke from the corrosion. What do you use for a hold down of the battery if any?
Thanks in advance
Kevin
