1985 Digital Display Problem
Old May 20, 2005 | 04:18 PM
BillFla's Avatar
BillFla
Default 1985 Digital Display Problem
I'm hoping that someone out there can help me. The digital display on my 1985 C4 periodically goes very dim- almost to the point where you can't see what is being displayed-although what is being displayed is correct. At the same time the directional arrows and high beam indicators are illuminated. Does anybody have a clue what this is all about and how to fix it?
I'd greatly appreciate any help.
Old May 20, 2005 | 05:24 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The quick answer: It's bad ground.
Old May 20, 2005 | 05:45 PM
cyclebuyer's Avatar
cyclebuyer
I just fixed the same problem a couple of weeks ago. It wasn't very hard but I was lucky. The ground prong was discolored, very dark. I just cleaned it up & now it works fine.
Old May 20, 2005 | 05:52 PM
cyclebuyer's Avatar
cyclebuyer
Check out this site...
http://www.batee.com/corvette/index.shtml
Old May 21, 2005 | 01:16 AM
okies93's Avatar
okies93
St. Jude Donor 06
my buddies 84 has gone out twice in the last few years. almost sounds normal. he sends his off to be repaired
Old May 21, 2005 | 02:16 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Interested in a quick lesson on how to reset your odometer? Includes the proper method of marking the door jam with the mileage change...
Old May 21, 2005 | 02:49 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Old May 22, 2005 | 08:20 AM
BillFla's Avatar
BillFla
Took the cluster apart yesterday and found exactly what you described. Cleaned it up and now works great. Thanks a million-you saved my some serious money!!
Old May 22, 2005 | 11:56 AM
Jayman's Avatar
Jayman
[QUOTE=JrRifleCoach]Interested in a quick lesson on how to reset your odometer? Includes the proper method of marking the door jam with the mileage change...
Is this method used for installing used clusters to match mileage? I would like to know the proper procedure.
Old May 23, 2005 | 12:37 AM
CMYC4GO's Avatar
CMYC4GO
Most probably, it's your power supply. There's a guy in Indiana that rebuilds the instument cluster for around $200. His name is Gene Tabor
His phone number is 1-888-454-1911
His website is: http://www.corvettedashclusterservice.com
His E-Mail is: genetabor@aol.com
He completely rebuilt my cluster from top to bottom when I still had an 85, and did a outstanding job!
Old May 23, 2005 | 12:44 AM
yellowlust's Avatar
yellowlust
When it goes again, run a jumper wire for the ground.
Old May 23, 2005 | 09:04 AM
cyclebuyer's Avatar
cyclebuyer
Way to go BillFla!!!!!! Doesn't it feel good when you can repair something yourself!
Old May 23, 2005 | 01:02 PM
rad928music's Avatar
rad928music
YES!
I had the same problem on my 1986 corvette, im a electronic technician/ computer repair tech so i thought id take it apart and do the most basic test sight, smell and see what was going on, wow the electronic they used on these breadboards is shocking by todays standards no multi laying , just wire to wire surface contact layer
by a one side conductive/insolated tape thats been sprayed with
a none conductive rosin, then i noticeed what you guys are talking about a connector string board mount with prongs comming up from a daughter board and the groung pin and a couple other black with
carosion, i traced it down to the prong lever and notice 3 very bad solder joints ( the cause of this common problem with these displays
it seems that who ever built these use poor solder practices ( common in a low quality manufacturing enviroment.
I resolder and cleaned contacts and it as good as new.
so before you go sending you display out or buying another one for hundreds of dollars check it out.
Old May 23, 2005 | 05:57 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
My whole dash doesn't go dim, but the left center section does. Is this the same problem or a bulb issue? Are there bulbs behind the silver circles I see on the front of the assembly?
gp
Old May 31, 2005 | 05:45 PM
GREGGPENN's Avatar
GREGGPENN
ttt
Old May 31, 2005 | 07:16 PM
nitronick's Avatar
nitronick
Active Streak: 90 Days
gp
Probably bulbs. Be prepaired. They are 6 to 8 bucks each! It was easier for me to pull the cluster apart and change them.
Old Jun 1, 2005 | 10:18 AM
cyclebuyer's Avatar
cyclebuyer
GreggPenn...
That's just a blown bulb. You don't have to pull the whole cluster out. The 4 silver/aluminum clips you see on the front cover 4 bulbs. The bulbs are a pain in the butt to replace, but I replaced one yesterday. Radio Shack has the bulbs. (882 or 891)
http://www.batee.com/corvette/dcrg/lightbulb.shtml
To 1985 Digital Display Problem
Old Jun 2, 2005 | 02:51 PM
GREGGPENN's Avatar
GREGGPENN
Thanks.
What if it works sometimes? Would you still suspect the bulb, the plug in question (from the original poster), or a loose connection anywhere along the way?
gp
Old Jun 3, 2005 | 10:01 AM
Casethecorvetteman's Avatar
Casethecorvetteman
just bang on the top of the dash,that will fix the barstard!!!
Old Jun 3, 2005 | 10:04 AM
Casethecorvetteman
Thanks.
gp
mate id say pull the bulb out and bend the contacts out a bit for the bulb holder. might just be a dirty or loose connector in there somewhere. Just clean them up and make them push harder on the contact points.
