I'm building a 1966 resto-rod with a tube chassis that accepts C4 components. Is there a major difference between the 1985-87 and 1988-96 front steering geometry enough to make me choose the latter over the former for sure? And other than the 88-96 caliper being 2-pistons, anything else different between the brakes? Are the 2-piston calipers that much better than the one-piston? I don't have plans to upgrade to 13" rotors/calipers since the wheels will be 16" and the big brakes won't fit.
The frame accepts only 1985-87 upper A-arms, is there a problem in using those A-arms with the rest of the 1988-96 set up?
Finally, any suggestions on the steering rack? Any major differences there between years?
Hmmmm, that would be a moot point since I'm not using the spring, it will get coil-overs. I won't use a sway bar either. I saw pictures of the spindles side by side and they are quite disimilar. You can't put 85-87 brake calipers on the 88-96s, but that does not mean the 88-96s are better, right?
I don't know maybe someone else will chime in. All I know is that the heavy duty brake option came standard in '95 and that is with 13" rotors I beleive.
The changes were mostly in mounting points and approach to handling, general geometry stuff for the former, and a switch from stiffer springs to larger swaybars and geometry to get the same handling in the latter. Entirely to improve the ride quality.
One geometry is not really better than the other if racing/handling is your viewpoint. Its not like an 89 will run circles around an 85, for example, if you gave them the same power.
The parts will not interchange, and it would require some real fab work to make parts from either setup to work together. I would just take the whole front-end of one or the other.
With mounting adapters though, you can use later model brakes on the earlier models, so theres one thing you can play with. Most of us with early C4s are putting on C5 brakes now anyway, I did. More fade-resistant.
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Is that a '66 Vette you're talking about? That will be a sweet driving car w/ C4 stuff under it. They never made a bad C4 set-up. And since you're using coilovers, obviously you can easily tune it to whatever you need it to be. I'd love to see pics of that chassis when you start construction.
wow, thats a big project. how long from start to finish will it take you. a project that we all dream of.
I'm almost 2 years into a 4 year project. I have collected all the hard-to-find parts like bumpers, gauge cluster, stainless trim, etc. with the exception of the headlight bucket assemblies. I do have a lot of fiberglass repairs to do on the body. The last year of the project (2006-7) is when the fun begins and I purchase the engine/tranny combo - an LS2 with a Keisler 5-speed. And, yes, it will be a driver, not a trailer queen.
