Trailering a vette
Old May 25, 2005 | 11:53 PM
rda2w's Avatar
rda2w
Default Trailering a vette
Will a C4 go onto a Uhaul flatbed trailer without tearing up the front valance? ba
Old May 25, 2005 | 11:58 PM
85vet's Avatar
85vet
Cruise-In V Veteran
You might have to put a few 2x4's(2 per ramp) about 2 foot long in front of the ramps to lift it up. I do this on my trailor all the time.
Old May 26, 2005 | 12:13 AM
Gary04Z06's Avatar
Gary04Z06
Watch the fender height, doors might not clear and you won't be able to get out.
Old May 26, 2005 | 08:01 AM
Strick's Avatar
Strick
Get a trailer that has a removable fender so you can open the driver's door.
Old May 26, 2005 | 08:55 AM
FastZR1's Avatar
FastZR1
Veteran: Marine Corps
I used a U-haul the first time I needed to move my vette and I removed the front air dam just so I didn't have a problem.
It would have rubbed bad if I didn't remove it.
Old May 26, 2005 | 11:53 AM
vettefast's Avatar
vettefast
I have no problem putting my Vette on my open trailer but I do have the removable left fender on the trailer which you will need unless you plan on doing a Dukes of Hazards exit.
Old May 26, 2005 | 04:34 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I've used both u-Haul & Budget car haulers.
Is you car lowered at all?
If so, you'll tear the exhaust out of it!
Old May 26, 2005 | 06:09 PM
jrace's Avatar
jrace
I hauled mine with Uhaul trailer in Dec last year. I recommend that you put a 2X6 under the ramps to so nothing scrapes underneath the car. Also make sure you get a trailer that you can lower the left fender.
Old May 26, 2005 | 10:25 PM
Jim Nichols's Avatar
Jim Nichols
As much as I dislike "trailer queens", I am having a trailer modified for my 91 Coupe. With the ground effects and side pipe I only have a little more than 3" clearance.
Old May 27, 2005 | 09:09 PM
ballox's Avatar
ballox
Here's my 87. picked it up in March . Slight rub going up the ramps but can be avoided by laying 2X6 on approach to ramps.
The uhaul fenders do fold down but unfortunately you still cant open the doors so get ready to crawl out the back hatch !
Mike
To Trailering a vette
