Error Codes
Old Jun 9, 2005 | 05:34 PM
Sirwilliam1229's Avatar
Sirwilliam1229
Default Error Codes
I have a 1989 Vette, with a newly rebuilt engine. Sinces returning from the shop, I have been gettting codes 13 and 33. What's going on?
Old Jun 9, 2005 | 10:47 PM
PierEagle's Avatar
PierEagle
Code 13 - O2 Sensor is not going closed loop.Could be the sensor or the ECM. Check to make sure connection on sensor is secure and sensor not damaged.
Code 33 - MAF Sensor Circuit. First thing I would do is check to make sure the MAF, MAF Power Relay and Burn-Off Relay are securely plugged in. If they are, the next cheapest thing I would do here is replace the MAF Power Relay and the MAF Burnoff Relay. They are about $10.00 each, or less and easy to replace. Remove neg bat cable when you do. This will clear ECM code and allow you to see if it resets.
Advise progress.
Old Jun 11, 2005 | 02:47 AM
Sirwilliam1229
Thanks! I will check this out tomorrow! Also, I just replaced the relays, b4 for I sent the car into the engine rebuilding shop.
Old Jun 13, 2005 | 01:09 AM
PierEagle's Avatar
PierEagle
Just curious. Were you able to solve the problem? If so, what did you have to do?
Old Jun 13, 2005 | 06:05 AM
Sirwilliam1229
I pulled the codes, and then disconnected the negative cable. After which, I have not seen any codes.
Old Jun 14, 2005 | 12:49 AM
PierEagle's Avatar
PierEagle
Super. Hope that's the end of the problem. Thanks for responding.
Old Jun 15, 2005 | 05:43 PM
y2kredvette's Avatar
y2kredvette
Default Code Yellow Traction Control Handling
Does any one know the way to get the code's out or clear? Please let me know step by step.
My body got a Yellow vette w/errors - Traction Control/Handling Lamp On and Driver Info Center Displays Service Hndlg (Handling) (repair/Reprogram ABS Module) Model Year: 2001.
Thanks in advance
Old Jun 26, 2005 | 09:01 PM
Sirwilliam1229
I checked the connection, which seemed questionable, and repaired that. Now I only get code 13 at around 60-75 MPH. But, now it is a soft code. Next weekend, I will replace the sensor.
To Error Codes
