lightning problem???
Old Jun 17, 2005 | 11:04 AM
Moxxi's Avatar
Moxxi
Default lighting problem???
This is a 1985 Coupe.
This morning, when I turned on my lights, all I had were headlights. No running lights, side markers, nothing. No instrument lights, either.
I turned on the fog lights, nothing there. I didn't have time to check any fuses. Had to get to work. I did touch the brake light lenses once I got to work. The lenses were warm, so the brake lights are working.
I noticed that, even though the outer lights weren't working, the dome light still works. But, as I turn the headlight switch, the light on the radio doesn't change. It just stays bright.
Could this be a headlight switch problem, or is it something else?
Old Jun 17, 2005 | 11:33 AM
86_RedRider's Avatar
86_RedRider
Cruise-In V Veteran
St. Jude Contributor '03 & '05
at first i thought your car was hit by lightning.
not sure about the problem though.
Old Jun 17, 2005 | 11:35 AM
CMYC4GO's Avatar
CMYC4GO
You have a fuse out. Your tail/markers, and dash lights are on the same fuse.
Moxxi's Avatar
Moxxi
thanks for the heads up on the spelling.
Old Jun 17, 2005 | 11:38 AM
Moxxi's Avatar
Moxxi
CMYC4GO -
Thanks. I'll check the fuses tonight.
I was sure I was going to have to dig deep into my wallet to fix this one.
Old Jun 17, 2005 | 03:36 PM
jeverly's Avatar
jeverly
My mother had a 90 model acura legend that got hit by lightning while she was driving it. She didn't know it hit her, just that it hit really nearby. She said after that it started doing all kinds of funky things - power locks, radio, etc. all acting funny. She took it in, and they put it up on the lift, found 4 grey spots on the tires and the top of the radio antenna was sort of melted. She traded it in and got a new one - they told her there could be so many electrical problems that it could take quite a bit to fix. Not sure if that was true or not, but she replaced it with a 99 TL.
Old Jul 1, 2005 | 01:03 PM
Moxxi's Avatar
Moxxi
CMYC4GO-
That's what it was.
One 10 AMP fuse.
Thank you very much.
To lightning problem???
