Stripped Stud
Old Jul 2, 2005 | 04:30 PM
midlifecrisis91's Avatar
midlifecrisis91
St. Jude Donor '03-'05-'06
Default Stripped Stud
I changed my rear tires out for some new ones and found that one of my wheel studs was a PITA to get off. The threads were all buggered up. Is it hard to take off the rotor and change out the stripped stud? If so, what is the best way to do this? I don't like running around with four lugs on. Thanks for any suggestion....
Old Jul 2, 2005 | 04:53 PM
Silverbrick's Avatar
Silverbrick
Buy one of these from your local auto parts store. Just ensure that it will fit the stud. You should be able to get a new stud from your local GM dealer.:
http://www.kentool.com/Wrenches_-.htm
Old Jul 2, 2005 | 05:26 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Once you have the new stud put a socket over the head behind the wheel hub and use a large C-clamp to press the stud out and the new one in.
Old Jul 2, 2005 | 09:47 PM
John A. Marker's Avatar
John A. Marker
I also put a little anti-seize in the hole before installing the new stud. If you have an impact, you can use a couple of washers between the stud and a nut and tighten.
After you install and torque the wheel back on, with in the next five miles re-torque that stud. You will find that it will loosen up.
Old Jul 2, 2005 | 10:05 PM
mseven's Avatar
mseven
Pop old one out w/a hammer start (push) in new one. you then can use a lug nut w/washer tighten the nut down till you see that the stud has been sucked in flat to the back side of the rotor. If rotor is frozen this can still be done on the car w/out removing the rotor, just have to line it up back side were stud is to the smallest side of the hub.
Old Jul 2, 2005 | 10:16 PM
bogus's Avatar
bogus
the studs are on the wheel bearings.
Old Jul 3, 2005 | 10:45 AM
midlifecrisis91
The rotor is not frozen, and is it that hard to remove the caliper so i can have a little of room to work with it? Will I need to remove the brake line and loose fluid? It seems fairly easy,but, I have not done anything like this before. I have to be in a 4th of July parade tomorrow so I will attempt to do this afterwards. The mechanics in town want like $150.00 to do it. I will pick up a wheel stud and lug nut from the chevy dealer in town today. Hell, I'm not gonna pay that kind of price for this. They must be smoking something from Canada. Thanks for all the input. Bogus, to bad you don't live in Washington State.
Old Jul 3, 2005 | 10:48 AM
myvettesblue's Avatar
myvettesblue
St. Jude Donor '05
but can you change it with the wheel bearing in? is there enough clearance?
Old Jul 3, 2005 | 10:50 AM
myvettesblue
St. Jude Donor '05
you can remove the caliper without having to remove the line just use an old coathanger wire to hang it up so it isnt hanging from the hose then the rotor will slip off and you will then have access to the studs
Old Jul 3, 2005 | 12:27 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Yes you can, I'm about to change all 10 rear studs. Very simple job. I've done it many times, no need to remove rotor or disconnect anything, the only obvious thing is to remove the wheel.
Old Jul 3, 2005 | 01:49 PM
myvettesblue
St. Jude Donor '05
To Stripped Stud
