Window problems
Old Aug 2, 2005 | 06:06 PM
jay17's Avatar
jay17
Default Window problems
I need to change the switch on my window and I'm wondering what the best way to remove the door panel is?
Thanks for the help,
Jay
Old Aug 5, 2005 | 12:13 PM
jay17's Avatar
jay17
Anybody?
Old Aug 5, 2005 | 12:26 PM
chevyc4's Avatar
chevyc4
Which door?
Drivers Side: Two screws in door handle and lift out the window/mirror controls, remove the manual lock rod cover (pops off), remove light and remove three screws near release handle, remove release handle bezel, remove 5 or 6 pop clips at the bottom of the door panel, lift up on door panel, disconnect all the wiring harnesses
Passenger Side: Remove window switch with a small flat blade screwdriver, remove the two screws in door handle, see above (same as drivers)
Old Aug 5, 2005 | 12:36 PM
Jet-Jock's Avatar
Jet-Jock
Originally Posted by chevyc4
Which door?
Passenger Side: Remove window switch with a small flat blade screwdriver, remove the two screw in door handle, see above (same as driver)
Correct. The whole driver door insert comes out there are pressure fittings near the top where the mirror control is. Lift it out from the rear.
Passenger door use a small flat blade and pry from the bottom until its just loose the from the rearward side pry up. It will pop out. Pull it out some and disconnect the two wire harnesses.
To Window problems
