Help
Old Aug 4, 2005 | 08:01 PM
Dr_737's Avatar
Dr_737
Default Help
Anyone here ever install the cross frame from a convert onto their coupe. The front lines up and bolts on - no probs. There is nothing to mount to on the rear? Has anyone done this before.....
Old Aug 4, 2005 | 08:08 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Use tje Search function. I know someone discussed this recently. I took a C4 class recently and we discussed this. I'm at work. I will look in my class notes when I get home and see if I wrote anything about this.
Just remembered. Chris Petris said to use a punch to make a nice hole in the frame where the bolts should go. Then use some good-sized sheet metal screws/bolts to attach them to the frame. The class member who asked about putting the X brace on his 93 coupe was a weekend road racer. Chris said this would do the job!
