Programming Keyless Remote
Old Aug 7, 2005 | 09:38 PM
mdell2's Avatar
mdell2
Default Programming Keyless Remote
I have the keyless remote for my 94 LT1, but the original owner never had it programmed. Do I need to go to the dealer or is this something I can do? Any help greatly appriciated.
Old Aug 7, 2005 | 10:12 PM
Illvtvette's Avatar
Illvtvette
Here is how to program your 93-96 FOB 1. Move your transmitters out of range (20-30 Ft) 2. Turn on the ignition 3. Push the Trip ODO button on the driver info center twice 4. With in 5 sec. press and hold Fuel Info button until the passive keyless entry light comes on. 5. Turn the ignition off but leave the key in the ignition. (Passive keyless entry light should begin to flash) 6. Bring 1 transmitter into range. The light should stop flashing and stay on to show the code is stored. (If only one transmitter is being programmed skip to step 10) 7. If more then one transmitter is being programmed, bring the programmed transmitter out of range (The light should start to flash again) 8. Bring unprogramed transmitter into range. 9. Repeat steps 7-8 for all additional transmitters. 10. Take key out you are done.
Old Aug 7, 2005 | 10:14 PM
mdell2's Avatar
mdell2
Thanks, you guys and gals are great.
Old Aug 10, 2005 | 11:21 AM
nikkormat42's Avatar
nikkormat42
3rd Gear
Default No PKE light
I go through the procedure but my PKE light never comes on nor does it flash. I have turned the ignition to the on postion/cranked the car and every possible variation. Could there be a fuse that needs to be checked or replaced?
Old Aug 10, 2005 | 11:36 AM
chevyc4's Avatar
chevyc4
Check the power door lock fuse; if it is good then you may have a bad PKE module, which is a royal pain to get to. Also, if I am remembering correctly there is a PKE fuse, but I am not 100%. Just look in the fuse panel on the passenger side of the dash.
Good Luck
Old Aug 10, 2005 | 12:00 PM
ALLT4's Avatar
ALLT4
This might help....
Here I just copied this from another post of mine. Sorry for posting a pic from the manual. I know how some folks hate them.
This pertains to my 96 but should work for 95, 94, maybe others you’ll have to look and see. I’m assuming you have a known good transmitter. You know how to program it correctly. If not do a search and you should find many tips on it or use your manual.
A few preliminary checks should be done first to rule out anything stupid and not so obvious.
Fuses…
#40 RDO BATT 5A=provides constant power to the module.
#26 PKE 5A=provides switched 12 volts in run, bulb test and start.
#42 POWER LOCK= provides voltage to the indicator bulb and power door lock relays in the module.
If all those are OK you need to make sure your “Key in ignition switch” is working, this is easily tested by opening your door with the key inserted and listening for the warning chime. If no chime is heard you have either a defective switch in the ignition, the chime itself is just dead, or there is a wiring problem between the switch and CCM and/or the PKE receiver.
Now you’re saying, “that’s all good but it still won’t program” You need to make sure the module is actually alive and responding. Enter the diagnostic mode by jumping pins 8 to 5 on the DLC and inserting your key in the ignition with it in “Lock” position. Take your transmitter out of range for this. Do you have any PKE light activity? If NO the module will have to be accessed, if it’s working it should flash DTC 13 (one flash, pause, three flashes) bring your transmitter into range and make sure to move it around shake it, the DTC should change from 13 to either 14 or 15.
14 is good, it means your transmitter isn’t programmed or has a bad battery. (Unlikely since you can’t program it anyway.)
15 is bad, you have some system the CCM is looking at that isn’t in a ready state, door lock switches, courtesy light switches on the doors etc… you need to figure why the CCM isn’t happy. You’ll need the service manual for this there’s no way to figure it out without it.
In the case of no DTC’s the module just isn’t ready for some reason, you need to access the module by removing the dash cap. It isn’t that hard; don’t cut apart your dash frame inside behind the radio to get to it that’s what hackers do. Do it right and pop the dash off it’s only a number of screws.
You will see two boxes in the middle of the inner dash velcro’d together. The PKE receiver module is the one underneath. It can positioned to gain access to the terminals but it’s not easy.
Check all the inputs the thing needs in order to work…
A1=Ground, BLK wire.
A4=will go from 12 volts to 0 when you stick the key in the ignition. LT GRN wire.
A5=PKE fuse input, switched 12 volts. PNK wire.
A6=LH door ajar, 12 volts with door closed, 0 with it open. GRY/BLK wire.
A7=RH door ajar, 12 volts with door closed, 0 with it open. BLK/WHT wire.
A8=RDO fuses input, should be 12 volts at all times. ORN wire.
C=Lamp indicator, ground this BLK/ORN wire and the indicator should light.
F=Power Door Lock, hot at all times. ORN wire.
Your module may have some broken connections where the connectors finally make their way into the PCB of the module. It can be taken apart easily but re-soldering the connections isn’t so easy. The board has a coating on it for protection, you have to dig through the stuff in order to re-solder things.
I’ve included a picture of the pin outs from the receiver for reference and aid. Do yourself a favor and buy the Helms service manual. Even if you can’t fix your PKE with it you’ll need it for many other things.
I’m sure this isn’t all inclusive but it should help solve many problems folks have.
Old Aug 11, 2005 | 03:59 PM
nikkormat42
3rd Gear
Default Enter the diagnostic mode
Thanks for the great info!
Is this procedure documented/illustrated somewhere?
.....Enter the diagnostic mode by jumping pins 8 to 5 on the DLC
I think I know what you are referring to but I want to be sure. I was unsucessful in my search of this forum this info.
I have a Digital OBDII Code Reader that I bought a while back. Can I use this to troubleshoot the PKE problem?
Here is a description of the code reader.
--http://www.iequus.com/item.asp?cid=7&pid=3100
Jon
Old Aug 11, 2005 | 04:50 PM
Brian Blum's Avatar
Brian Blum
I want keyless.........
To Programming Keyless Remote
