interior lights
Just bought a '94 yesterday and I'm working all the bugs out like you are.
1) When you open either door, the Door Ajar light in the Dash Cluster should light.
2) Another indication the door switch on the Driver side (assuming you have a coupe) is working, open the drivers door and on the back edge of the Door panel, is a switch to open the rear hatch. If you press down on the switch and the hatch opens, the Door switch is good.
Do you know if an aftermarket alarm is installed on the car? If so, it's possible they cut the wire going to the CCM ) Central Control Module from the Driver side door switch so they could control the interior lights. The CCM monitors both Door switches and provides the ground path to turn on the Courtesy Lamp Relay.
You also mentioned the Security light blinks when you open the Driverside door. That's another indication the Driverside door switch is ok.
To gain access to the CCM wiring harness is not easy. You need to remove the plastic panel that the footwell lamp is mounted to and then remove some bolts holding the carpeted metal plate above the steering column.
On the side of the transmission tunnel you pull a small piece of carpet back which will expose a plastic panel held on by two screws. Once the panel is removed I think you need to remove a bunch of bolts holding a side bracket. Once the bracket is removed, you'll see the CCM. It's a metal box with two cable harnesses plugged into it.
If you ground Pin C12 a Black/Yellow wire at the CCM the interior lights should turn on. If it doesn't the CCM is bad. If the lights turn on, there is a wiring problem from Pin C12 back to the Driver side door switch or the switch is bad.
Look at the block diagram in the middle of the page of the CCM. There are two inputs. LH Door Ajar and RH door ajar. The CCM monitors these two signals. If either door is open, the Left hand Door switch or the Right hand Door switch will place a ground on the Input to the CCM.
Left hand Door switch is Pin C12 Black/Yellow wire input to the CCM and the Right hand Door switch is on Pin D16 Gray wire input to the CCM.
The CCM will then ground pin D12 Connector C1 (Gray connector) which will place a Ground on Pin 85 of the Courtesy Lamp Relay. This will cause the relay to close the contacts between Pin 30 and Pin 87 of the Relay and cause the interior lights to come on.
Since the Interior Light Relay operates properly when the Passenger door is opened, your problem can't be the Relay, Relay socket, Relay wiring or the wire from the CCM to the Relay. It must be the CCM is bad, wiring from Pin C12 Black/Yellow wire back to the Switch or the Switch itself or the ground wire for the Switch. That's why I asked if the Door Ajar Light comes on when you only open the Driver side door. (I think the ignition key needs to be in the run position before the Door Ajar Light operates on the Dash).
I was assuming when you open the Passenger side door, the interior lights operate properly.
If so look at page 8A-114-2.
There are 2 inputs to the CCM. One is pin C12 Black/Yellow wire from the Driver side Door Ajar switch.
The other input is Pin D16 Gray wire from the Passenger side Door Ajar switch.
If either input places a ground on either pin C12 or D16, the CCM will turn on the Interior lights.
From the Driver side Door Ajar switch, there is a Black/Yellow wire that goes to a Splice in the wiring harness (S201).
1) At the splice, one Black/Yellow wire goes to a Diode module which turns on the Door Ajar light in the Dash Cluster when the Driver side Door Ajar switch closes due to the door being open.
2)At the splice a Black/Yellow wire goes to the Hatch Release switch. With the Driver side door open, if you press the Hatch release switch located on the back of the driver side door panel (assuming you have a Coupe), the rear hatch should open.
3) At the splice a Black/Yellow wire goes to the PKE module. Passive Keyless Entry Module.
4) At the splice a Black/Yellow wire goes to the CCM Pin C12 from the Driver side Door Ajar switch.
So if the Door Ajar Light comes on when you open the Driver side door, that indicates the wiring from the Driver side Door Ajar switch is good up to the splice (S201).
So your problem must be.
1)There is a open in the wiring from S201 to Pin C12 of the CCM Black/Yellow wire.
2)The CCM is bad. To eliminate a bad CCM you need to gain access to the CCM wiring harness and ground pin C12. If the Interior lights come on there is an open circuit from Pin C12 to splice (S201). If the lights don't come on, the CCM is bad.
You need to understand there are two seperate inputs to the CCM that can cause the CCM to turn on the interior lights. One is the Driver side Door Ajar switch and the other is the Passenger side Door Ajar switch.
All the manual says about Splice 201 is that it's located Instrument Panel Harness, Lower Left Hand side of Instrument Panel. How that wire/circuit could be open is very strange. That's why I asked If you have an After market Alarm installed and maybe the installer cut the wire so the interior lights would operate with their setup.
(The relay socket slides off of the black plastic relay bar the holds the relay sockets in place).
