I have a 92 convertible and it's time for new rear break rotors. I see Eckler's and NetVet's have them for $59.00 each. I'm not sure which ones I need, though: standard or heavy duty?
Your thoughts? Also, are these rotors worth buying? I like the price, but not if the value is poor.
Thanks,
Chuck
I'm assuming that the "standard" rotors are the stock rotors, and the "heavy duty" rotors are the option J55 rotors? If that is the case you should find out what your car has and replace them. If you have the standard brakes you can upgrade to the J55 setup...but I don't know exactly what you need, but lots of people here have done it! Then of course there is the C5 brake upgrade...
Thanks for your help. So all rear rotors are the same, cool. Now short of pulling the front rotors and measuring them, how do I know which size I have there? Is there an RPO code I can check?
